Interior/Exterior Sidemarkers dont fit
Hi so i ordered some Blackjack LED sidemarkers off out motoring
http://www.outmotoring.com/mini-coop...al_lights.html
And i pulled off my current oem sidemarker and the plugs dont match up?
did i order the wrong thing? or am i missing something..
i have a 2005 MCS convertible
To remove the housing, you have to slide it back and then push out.
To splice, you disconnect the battery, cut the wires, strip off the insulation, twist the wires from the light to the car wires (one wire to one wire each), tape them safely with electrical tape, and then that's it. With most LEDs +,- polarity isn't a huge issue.
-this is NOT official electrical advice. This is the half assed way of doing things.
Call out motoring first, maybe they'll send you a different harness.
You havn't taken it apart all the way, the white male portion twists off of the lens, then you'll see how it plugs in.
as far as pulling the scuttle, should just pop out from the rear (near the door) and have a catch in the front, just be sure & use a piece of cardboard or a rag to protect your paint if you use a screwdriver to pry it out.
Edit: Now I'm 2nd guessing myself, I think it's back=pin & front=tab.
Still kinda stuck on the sidemarker housing tho :/ trying to dip it black.
Tried prying it from the near the door side with a screw driver but it just dosent budge, i also went inside the hole where the side marker light goes and tried to pull it out from the inside but nothing moved really.
trw92a
08-26-2015 01:47 PM
08-19-2015 12:51 PM
08-12-2015 01:24 PM
