Interior/Exterior Dorky Cheapskate Mods - Gen 2
#76
Then I proceeded to poke out the little burs that built up in the openings with a small flathead, and then went over each of the openings and the outside whit what is locally called a whirly-gig in the local shops. (one of these http://www.zorotools.com/g/00025925/...FdKj4Aod6U4AvA)
Then blasted it with a hose to clean out the scraps.
And Installed
As a disclaimer, I am not responsible for this going poorly if you attempt it yourself. An angle grinder can be dangerous. I was reminded of this with this mod when I wasn't paying attention as much as I should have been and bumped the edge of the spinning sanding disk with the knuckle of my right index finger. I've got two nice deep grooves cut into my finger now as a reminder. Be careful. Wear safety glasses and a good set of leather/welding gloves is a pretty good idea as well.
And Installed
#80
To reiterate what the two above have posted, There is no danger. With the mesh, a few more bugs may get in, and you may have a few more dusty parts on the top of your engine bay, but really that's it.
Using torque to measure coolant temps, my coolant temps take longer to rise and at the same speeds on the highway were generally about 3* celcius lower than with it sealed. I didn't think to see if there were any difference in intake temps(didnt take a before reading), but today in 75*f heat going 75mph my intake temps were 80.2*f so I have a feeling it's helping to keep that cool, plus under the hood cools quicker as hot air rises and the heat from the turbo has a very short and easy place to escape.
#81
on
I have the Mini Fini stainless grill insert, essentially the same thing.
#82
on
Today I removed the small stock clutch stop bump, and I added a "BMS Short Throw Clutch Stop" :
http://burgertuning.com/clutch_stop_mini_cooper.html
Best $10 ever spent.
The left foot equivalent of a short shift kit.
Do it.
Do it.
#84
Do it.
Do it.
#85
Do it.
Do it.
Finding the right shifting feel has been one of my only complaints with my MINI. I've driven manual for years but this one can be a challenge sometimes. I've already added the NM short shift adapter and a Whalen so this clutch stop is a nice addition. Thanks for the recommendation.
#86
Today I opened up the honeycombs in the hood scoop. Cost: $0, but I already had all the tools I needed.
So, What I did was put a sanding disk on an angle grinder and sanded down the backside of the honey comb so it was flat, applying no pressure to it except for the weight of the tool, and I kept it moving so the plastic sanded more than melted. heres what it looked like at that point.
I then proceeded working with a less gritty disk to sand down until all the openings opened up. Again, let the tool do the work and keep it moving so the plastic doesn't melt too much. If it starts to, stop and take a break for a minute. Should look like this when done.
EDIT: Found it.
#88
Ditto this...
I'm not sure how I missed this item for so long! Ordered two days ago and it arrived yesterday. It wasn't until after that I realized Burger Tuning is only a few miles from my house. JB+ is next on my list
#89
Changed Parking lights- 194 white Canbus LEDs from E-bay. 5 elements, plug right in.. No warning light. Just a few bucks. Got 4 of them free shipping. Did the rear tag lights too. Takes all of 1 min to change the bulb.
1 st pic - Passenger side is the stock w5w bulb, drivers is LED.
2nd pic - all LED front end (minus HIDs and Fogs..).
Very happy with the light color.. Looks like a much brighter (whiter) light.
#91
#92
#95
#96
http://www.ebay.com/itm/111091600244...84.m1497.l2649
Were the ones I used without an issue.
#97
#98
I felt this belonged nowhere else but under Dorky Cheapskate Mods
Rite Light Wireless LED Puck Light from Walmart http://www.walmart.com/ip/Rite-Light...Light/16627633
Dummy 12V plug from boot
Bolt, nut, lock washer
Cool features about puck light: wireless, 2-level brightness, doubles as a flashlight, bright, lens tilts and it's CHEAP!
LED boot light WITHOUT puck light
WITH puck light
WITH puck light
#99
#100
And Installed
And Installed
anew742 (02-27-2018)
