Interior/Exterior 2003 Mini Cooper S Aux Mod
It was just talked about in another thread but this will give you some options.
If you dont have it already in the glove box or under the toggle bank. Its a very popular upgrade for the Gen 1 MINIs. You will know if you have it or not if you see the aux in. Then using a 3.5mm jack connect to you device. Toggle through to you reach Aux on the screen with the Mode button.
Aux Input Cable Install Set Part number 82110153367
http://www.ecstuning.com/Search/SiteSearch/82110153367/ES194874/
Some people install it right below the toggle bank on the backside plastic cover.
3.5 aux jack. Part number 61122153331
http://www.ecstuning.com/Search/SiteSearch/61122153331/ES2145057/
Another option is the more integrated MINI Official IPod kit. Part Number 65110439432
http://www.ecstuning.com/Search/SiteSearch/65110439432/
Here is the install instructions. Its the previous part number that superseded to the one above.
We have the "Dice" Products also below.
http://www.ecstuning.com/Mini-2003-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Interior/Sound_System/Auxiliary_Input/
That gives you some options for direct connection.
I highly recommend getting the factory cable. It's a piece of cake to install. I've done one in the removable panel like in the picture above and one in a down tube. The panel was a lot easier.
I then got a bracket that mounts to existing screws on the radio, added a cradle, and had a very good iPod setup. I can't remember where I bought then anymore, though.
SosoMINI
11-22-2015 03:17 PM
08-07-2015 05:55 AM
