Interior/Exterior where can i get a lock on my Glovebox.
If you have electric seats ,put a stick from the front of the Passenger seat
to the glove box,TIGHT,or roll up the windows cause the least of your worry,s on a vandal
hit is a stolen map ,slashed seats.general pulling and ripping,beer ,pee,or other fluids dumped inside......Lock the whole car!!! insurance???
>>The lock is an 05 option. Why not lock your valuables in the boot if you must leave them in the car. If you lock the doors with the remote you cannot unlock them by pulling the inside handles.
Really? I'll have to try that. How about the toggle for the locks at that point? And climbing in the window and getting to the boot area is not that hard. :smile:
i like to keep my Digital Cam in the box and some othe paper stuff for the cop when they pull me over.
Boot? have you try to put everything in the boot and let them sliding around when you drive through a corner?
Ohh here is a hot chick want to take a picture with my car, sure! oh, sh*t my cam in in the back. let me run to the back and get it!
>>BTW, i'm sure most of you did not know there is a emergency latch under the back seat right?
>>life up the back seat the latch in the middle to pull and open the hatch! old thread
_________________
James - SCCA SFR GS # 96
_________________
>>use your key fob to lock the doors, the doors will not unlock unless you do it with the key or the fob, the interior switch will not work at this point.
Actually you still can. First you need to use the toggle switch to unlock the doors. Then give the handle a double pull and it opens up. I did it on my 10/03 build.
_________________
_________________
"Do you mind if i look round the car a little bit?"
Well my glove compartment is locked so is the trunk and the back
And i know my rights so you gon' need a warrant for that
"Aren't you sharp as a tack, are some type of lawyer or something'?"
"Or somebody important or somethin'?"
Nah i ain't pass the bar but i know a little bit
Enough that you won't illegally search my s***
Obviously, he's not driving a MINI.
