Interior/Exterior RE: Short Shifters
Old 03-24-2014 | 08:44 AM
daonlyillwiz's Avatar
daonlyillwiz
Haha its perfect for me. I dont use the arm rest so my arm sits a lot lower than if i was to use the arm rest, maybe thats why im cool with it
  #27
Old 03-24-2014 | 10:29 AM
Saltysalt's Avatar
Saltysalt
i dont have the armrest as well, but if you ever come to a vermont or NH mini event, i would definently like to see it and if my frames works for it!
  #28
Old 03-24-2014 | 10:43 AM
daonlyillwiz
Sounds like a plan
  #29
Old 03-24-2014 | 11:07 AM
minibx's Avatar
minibx
Or you could come down for the Hudson Valley Run on April 27th, If I remember correctly some folks from NH,MA&PA come down for this run, lots of fun.
  #30
Old 03-24-2014 | 11:16 AM
daonlyillwiz
ill be going to that actually so if you go Saltysalt ill be there.
  #31
Old 05-18-2014 | 12:29 PM
MiniJin's Avatar
MiniJin
I want to try and get some clarification on the Cravenspeed shifter, I understand it does shorten the throw also shortens the height that's great, but what if someone say my wife wants a shorter throw but not a shorter (height wise) shifter. So question is if you leave it at stock height will it shorten the throw? And if so by how much if anyone can shed some light on this for me that be great thanks guys. Oh almost forgot will the cravenspeed need a shifter assembly box cover like the NM shifter or any modification to the stochastic one?
(Also just I case anyone is wondering I did search and read this is the only thing I couldn't find info on clearly.)
  #32
Old 05-19-2014 | 08:52 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
That's a good question, and the answer is, unfortunately, no. The height and throw are adjusted together, not independently. The total movement is about 1 inch up and down. The change is height is not nearly as noticeable as the change to the throw.
As to the box cover, no one need one at all, IMHO. We have been running shifters without any cover on the bottom of the box up here in Portland on daily driven MINI's since 2006. Never had a single issue through tons of rain, a bit of snow and the gravel they put down for traction. So, while a modified box cover will fit with our shifter, I would keep your cash.
  #33
Old 05-20-2014 | 07:56 PM
MiniJin's Avatar
MiniJin
Sounds great just what I was looking for thanks for clearing that up Kellen. One last thing how much would you say the throw is shorten percentage wise when lowered the full one inch and I know it shortens it front to back does it also reduce the side to side say from first to third and so on.
  #34
Old 05-21-2014 | 08:34 AM
CravenSpeed
Vendor
Yes, the total change in throw is 42%.
  #35
Old 05-21-2014 | 08:55 AM
ra2fanatic's Avatar
ra2fanatic
I really liked the Craven SSK while I had it and will say though that at the lowest point, the throws can be kinda notchy and tight, and didn't feel as smooth going into gears, but adjust it a bit higher and you'll be fine. It's still short and it really is the best SSK out there besides going ***** to the walls for a CAE Ultrashifter.
  #36
Old 05-21-2014 | 09:11 AM
CravenSpeed
Vendor
That is why I think that the adjustability is important. The shifter is really all about feel, with this one you can set it to a spot where is feels right to you. That spot is different for everyone.
  #37
Old 05-21-2014 | 09:12 AM
ra2fanatic's Avatar
ra2fanatic
  #38
Old 05-21-2014 | 12:28 PM
daonlyillwiz
I have no problem with my ebay shifter, it does a great job and the throw/height is perfect.
  #39
Old 05-21-2014 | 12:56 PM
CravenSpeed
Vendor
Glad it works well for you. I think you'd be surprised at how much a small change to it could make, and I wonder if, given the option, you would set our to the same 'perfect' throw from your eBay shifter.
Just my opinion, thanks for offering yours.
  #40
Old 05-21-2014 | 12:57 PM
Saltysalt's Avatar
Saltysalt
dang didnt read this till now....
  #41
Old 05-21-2014 | 01:15 PM
daonlyillwiz
I wouldn't mind having your short shifter, it actually looks like a good quality product. The only reason i went with the ebay shifter was primarily because of cost. I was a little weary at first but after installing it i was quite surprised.
Listen, anything is better than the stock shifter lol
  #42
Old 05-21-2014 | 01:18 PM
CravenSpeed
Vendor
I certainly can't compete with eBay on cost until after we outsourced out stuff overseas, which should happen...never.
  #43
Old 05-21-2014 | 01:21 PM
daonlyillwiz
Totally understand...unless you start paying the staff $10/week which im sure they wouldn't like that too much
  #44
Old 05-21-2014 | 05:27 PM
minibx's Avatar
minibx
Ohh it was sooo much fun mate....maybe next year
Not my pics
Attached Thumbnails RE: Short Shifters-image-3594961122.jpg   RE: Short Shifters-image-3929577601.jpg   RE: Short Shifters-image-2865627433.jpg
  #45
Old 05-22-2014 | 04:49 AM
daonlyillwiz
Minibx, that looks awesome. I wasn't able to make it either because I was doing suspension work to the mini that day (I replaced the lower control arm bushings and I installed my coilovers/caber plates).
Next year I'll roll out
  #46
Old 05-22-2014 | 05:30 AM
minibx's Avatar
minibx
Originally Posted by daonlyillwiz
Minibx, that looks awesome. I wasn't able to make it either because I was doing suspension work to the mini that day (I replaced the lower control arm bushings and I installed my coilovers/caber plates). Next year I'll roll out
Yeah man it was a lot of fun, there will be a Sunrise run in July I think, that's a lot if fun too, bunch of MINIs motoring around Manhattan early morning with no traffic or less than usual at least.
That's a bit of work LCA is not an easy task.
  #47
Old 05-22-2014 | 05:51 AM
daonlyillwiz
Nice, I could probably make that
"not an easy task" is an understatement. I got the old bushing/sleeve out using nothing more than a little sledge hammer, flathead, airhammer, chisel set. both sides took me 4 hours combined. I was sore for the next couple days though lol
  #48
Old 05-22-2014 | 06:13 AM
HorseWithNoName's Avatar
HorseWithNoName
You don't need to, after thirty thousand miles of use the shifter quality and design is the best in the market and the best mod on my R56...
02miniSguy
11-17-2015 10:29 PM
vetsvette
10-01-2015 12:59 PM
ToroPerro
10-01-2015 12:54 PM
MINI Stupor
10-01-2015 11:36 AM
Samhillrocks
09-29-2015 12:55 PM
Quick Reply: Interior/Exterior RE: Short Shifters
