Interior/Exterior Best way to get replacement headlight lens
so this happened to one of my lenses, dont ask me how:
ive tried everything to fix it with no results so i was wondering the best way to get a replacement. will i have to buy a used headlight and take the lens off? would a halogen housing lens fir onto my bi-xenon? thanks!
You have a gen1 judging by you other postings....
so no Bi-Xenon.....
You have Xenon lows/Halogen Hi beams....
There were 2 different versions....
a pre 2005 reflector version..pretty cheap used (comparatively), and the 2005+ gen1 "facelift" version...with lenses..pretty $$$, even used, but much better working.
so no Bi-Xenon.....
If you do get a new or used replacement headlight, just swap the entire housing. The lens is bonded to the housing and not designed to be removable.
IQRaceworks & yetti96 are Dead on the Money!
Got to Walmart or Amazon and get the
use this lit with a low speed cordless drill, 15 to 17$ and an hours worth of work and you will headlight that you can be proud of.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
