Interior/Exterior Headlights & aftermarket H7 bulbs
The other day I noticed that one of the day-time running lights was burned out. So I opened the bonnet, pulled the rubber cover to get access to the dead bulb. When I pulled on the plastic connector, part of it crumbled in my hand. The plastic appeared dried out and felt brittle. I looked at the other three connectors and felt one of the other connectors. All the same, dried out and very brittle.
I talked to my local mechanic and he said that the current aftermarket H7 bulbs appeared to generate more heat than the stock bulbs. The heat generated also melted some of the plastic insulation off of the wire.
So to get around to my question, does any one know what size the H7 connectors are??? I feel that I must replace all four of the connectors just to be on the safe side. Has anyone else experienced this problem???
Originally Posted by rg
Why not get direct replacements at the dealer?! And go back to standard bulbs. Sounds like your asking for trouble with the bulbs you've got. Hot bulbs...deteriorating connectors...sounds like a good old fashioned Lucas attack waiting to happen.
i seem to remember somebody who had their turning signal (on the front) get messed up and somehow had the connector break, but not the bulb. I say just grab a service guy, show him the part you need, and order it. I seem to remember that turning signal's connector being like... $20? i cant be sure.
molala
10-02-2015 01:53 PM
dandw2
09-06-2015 03:14 PM
09-04-2015 02:34 PM
