Interior/Exterior H7 bulbs interchangable?
I just wanted to swap out the high beams yellowish light with a whiter light that is also 55W. Since the DRLs are at reduced power, higher heat shouldn't be a factor right (4000K vs. 3200K)? Otherwise, I rarely have the need to use the high beams.
This is what I had in mind. I don't want any blue, just clear.
http://www.powerbulbs.com/products/p...id=oss&type=H7
I have Phillips Blue Vision bulbs on my MINI. I know of others that have Sylvania Silverstars on theirs. Much whiter than stock, and they seem to be brighter, too. They put out a 4,000 k colour (The temperature is an indicator of the colour, not the heat produced) Which is close to the colour of daylight (4,200 k)
Originally Posted by MiniMac
I want to change out the bulbs in my MINI.
What have people used?
I read a while back that one guy had his buld connectors dry up and crack
apart because of the extra hear generated. I have held off because of that.
I have had the daytime running lights turned on since day one, this I also believe may have contributed to the heat problem.
First of all, I do not think that the OEM H7 bulbs give off enough light, so I changed the to a set that were brighter. It turns out that these also produced a great deal more heat. Thus my problem. Since implementing my solution/fix I have had no problems, and have learned a little more out about my MINI. The new H7 bulbs are PIAA and are very bright and very white, which is what I was after.
:smile:
I just installed the H-7 Silverstars in my highbeams. (HID lows) Not real crazy about them. Yes, whiter light and looks cool if looking at it on coming but, I don't think they project as far out as the OEM highs. When I flip the Highs on, it is a whiter light and I can see higher and wider but.... just doesn't project much further than the low beams.
10-01-2015 12:13 PM
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
