Interior/Exterior looking for a real cheap way to Paint the black trim pieces!
I want to paint the black trim pieces around the car.
I have a DS/W MCS, it will be cool to paint those cheap black plastic looking pieces around the car into silver.
I have ask people around, but it seems very expensive since it needs to be sanded very well.
I decided to try my luck and see if anyone knows a cheaper way to do it!
I had this done on my last MC, extra set of plastic primed-sanded-painted, and it ended up costing at least $1k altogether, plus it took a long time to get done. Someone in our local club had it done without sanding (they just spray it several times and it fills in smooth) which cost less, and looks as good to me.
If you're good with painting, you can get some paint mixed here:
www.paintworldinc.com
www.paintscratch.com
both are reputable companies that make factory match paint.
Paintworld is much quicker on turnaround. I think I jotted down
somewhere how I would paint the arches, so run a quick search
and I think you'll find it. :smile: It would be the same way for the
bumper trims.
You'll need:
1. Adhesion promotor (autoparts store) 12oz
2. Primer with flex agent 12oz (you might need 2 cans)
3. Base coat 12oz
4. Clear coat 12oz
5. Wet sanding paper (400grit, 1500grit) and sanding block
6. Compound
It takes a lot of pratice to make the finish shiny and glossy like
how the bodyshops do it, so you might want to keep that in
mind before you start.
bumper trims.
You'll need:
3. Base coat 12oz
4. Clear coat 12oz
6. Compound
i did a how to write up here: https://www.northamericanmotoring.co...ighlight=paint
it tells how to take each part off, how to have it painted, and costs. good luck. chad
07-16-2020 12:54 PM
mrjolliff
10-09-2015 05:55 AM
