Interior/Exterior Flash2Pass Garage Door Opener
FYI for anyone interested, here's a link to Mini2 regarding what I consider to be a neat garage door opener remote for the MINI.
http://www.mini2.com/forum/showthread.php?t=72919
FWIW, it works for me, and it's cool
I installed Flash2pass. Pretty cool. Works as advertised.
Couple caveats:
1) the first spot I mounted the box under the bonnet didn't work when the bonnet was closed. Tried a second spot that was less blocked by metal, which works reliably now.
2) twice I've had to re-clamp the scotch-loks. But that would be installer error.
Couple caveats:
just recieved a used toggle panel from a fellow NAM member and I decided i'm going to use the ASC position to hook up the garage door opener since I don't have the option. The F2P is nice, but as i remember it was quite expensive and I don't like the idea of the remote just hanging around outside. Anyways i figure i should make good use of the extra toggles.
I suppose if you really wanted, you could splice the wires and run the box somewhere else, but I would think the box is fairly immune to weather.
And yes, it's a bit pricey ($100), but for me who's really into gadgets, it was cheap.
07-16-2020 12:54 PM
spackletooms
09-01-2015 10:12 PM
caiken
08-30-2015 05:34 PM
SoCalledFriend
08-06-2015 06:59 AM
