Interior/Exterior Alta Short Shifter
#26
(goting OT) What is happening is the door panel is smacking against the metal door with the vibration because it's not held tight enough. With felt there, it is smacking against the soft felt so there is no sound. Dynamat isn't much softer than the door so it won't help much.
But if you put some dynamat on the door and panel it may bring down some of the vibration. But not stop the rattling. Two different things going on. (It might also be thick enough to push more on the door panel and stop the rattling that way tho)
#29
#30
on
