Interior/Exterior Adding power folding mirrors
Think I found it also...
http://www.realoem.com/bmw/enUS/show...03#61319354861
61319354861
OK, nothing to see here, carry on.http://www.realoem.com/bmw/enUS/show...03#61319354861
Last edited by CooperT; 12-12-2017 at 05:21 AM. Reason: Link to door switch panel if anyone else is interested...
You guys are as bad as Abbott and Costello! Or Penn and Teller! Tom and Jerry?
Anyway, a couple of more questions on this if anyone has anything other than Itchy and Scratchy here. :-D
Found a good price difference in mirrors. One says Genuine Mini ($375), the other Genuine BMW ($272), both the same part #. I assume that means they are interchangeable? https://www.ecstuning.com/Search/Sit...h/51167401098/
You know ECS reds these posts!!!
It was a duplicate error on the site, the BMW price was wrong. It's a Genuine MINI only part. If you see them let me know.
" 8675309 " Not a Genuine MINI part but could be only the manufacturer part number... https://www.ecstuning.com/Search/SiteSearch/8675309/ ... no luck there
Its here on the bathroom wall:
Yep forgot the dash, still no luck.
Any luck? Interested in doing the same retrofit on my 2015 F55. Bought it used a few days ago, and it's missing this option. Don't really care other than the fact that without power folding, the vehicle will not tilt the passenger mirror when in reverse ... kind of annoying as all my otehr BMWs have this ... but the MINI doesn't ... so missing the function sorely when reversing in the MINI
You can code the tilt with Carly app or Bimmersomething on your BMW's if it's an issue for you
i already use ESYS and have extensively coded the f55, however with the tilt already coded it isn’t working. I will go back and compare the coding from my f85 to the f55 to see if additional codes need to be changed beyond the standard, which is already coded.
2019 f55 s
Was anyone able to get this working? I am curious about buying the parts and installing, I have the little mini projector in my driver mirror so id assume the wiring is all there to do the power folding, just would hate to buy the parts install them and not be able to get them to work
I had the 5 pin one which is the manual folding and just had to make some modifications to make the power folding ones work!
Best thing to do would be removing a mirror to see how many pins it has and then removing the connect that goes to the driver switch where you control the mirrors, that way we can see what wiring is there.
