Interior/Exterior How-To: Clear Corner Marker Install
#27
Originally Posted by racinbmw
Anybody know where to find these? They are all gone on Ebay.
No thanks to FedEd losing my package for two days, I finally recieved my clear corners yesterday, and installed them today.
The fronts were easy, took almost no time at all. I used tradiuz's install method for the fronts.
The rears were a pain in the a$$!
There was no way I could gently peel back the trim as tradiuz states. I found it to go much easier to jack up the car, and unmount the wheel well trim pieces to help move them out of the way. Never fully removed them though, just bent them back, but I had to have the rear corner jacked up to do this. Although I still cut quite a few knuckles while installing the rears, it was worth it, the 4 new clear corners look awsome.
Thanks to both "Pir8 97" & "tradiuz" for their write-ups!
#28
Originally Posted by SCMCS
I would like to replace the corner markers with clear ones but want to get colored bulbs (amber and red). There is a site that sells LED bulbs with these colors http://autolumination.com/
My question is what are the corner marker bulbs called? In the owners manual I do not see a reference to these lights and on the site that sells the bulbs they list several lights of which the only ones that seem that could be the lights are referred to as Parking lights or Front side marker lights both have a part number of 2825.
Is this the correct light bulb and part number? If so the LED part number should be # 194.
Cheers
Cheers
Does anybidy know if this is the correct bulb for the corners markers - #194? If not, know what is?
#29
Originally Posted by _freakmonkeydogboy_
Bringing this one back from the dead I see.......
Originally Posted by AZMCS
A run down by location and bulb is here:
Front Running Lights: #194
Front side turn indicators: #194
Wheel Arches: #194
License Plate: 39mm Festoon x2 bulbs
Step/Entry Lights(under doors) #194
Foot wells #194
Glove Box #194
Map Lights #194
Dome Light-Center Bulb 39mm Festoon
Dome Light-Side Bulbs #194
Boot Light #194
Tail lamp Assembly #1156
Front Turn Indicators #1156**
Wheel Arches: #194
Foot wells #194
Glove Box #194
Map Lights #194
Boot Light #194
#31
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
