Interior/Exterior Aero kit question
Sometimes it's all in how you get to that 100 pounds. It's a lot easier to remove 1 pound from 100 places than it is to remove 100 pounds from 1 place. I have doubts that there is any difference at all, but I just thought I'd see if anyone else had even considered it.
If I was seriously worried about the weight, I wouldn't have bought a car with a sunroof or the Premium package. :smile:
Originally Posted by KevinR
I was only asking for curiosity's sake; whether or not it weighs more (or how much more or less) doesn't really matter.
Assuming that the materials are similar then the design would determine the relative weight. Hardware is similar since the mounting points are the same.
Usually the inner door sill is removed and not replaced but the outer side skirts get a small additional grill.
Another concern is the paint process/ paint weight- if similar to factory in number of coats and clear coats then it should be close. If you paint the fender arches then that adds paint.
I'd guess that the weight would be pretty close and maybe a bit heavier with the painted aero kit with painted arches. Maybe 5 pounds difference if that much which would be minimal.
Anyone that has an unmounted aerokit can weigh the front and rear bumpers ,side skirts and grilles. Then remove the stock parts and weigh all of them for a comparison number. If the two totals are close then add the weight of the primer and paints to the aero total to get the difference.
07-16-2020 12:54 PM
ebowling
90
08-04-2019 09:15 AM
12-23-2015 10:36 AM
