Interior/Exterior M7 Front Splitter?
Hi Hounddog,
M7 front splitter is just Great I've had it on for over a year and it still looks new. Contrary to people's perception, it is not very vulnerable as long as you're not a klutz when it comes to parking up against curbs. It doesn't sit any lower than the bottom of your bumper. In fact, the only thing that has ever touched the ground while negotiation steep driveways is the lower airdam extension that's on all Minis.
Installation is very simple and straight forward. It bolts up to the bottom of the bumper and the standoff is attached to the facia. There is required drilling for both locations but if you measure twice, you only need to drill once. To date, the facia has not cracked so the design is very sound. The only modification I made to it was to install a few extra bolts to fill in between the supplied mounting to make it extra stiff. Give Peter a call
Originally Posted by Hounddog
This is stupid but I can't find it on the site.
Wayne
Found them right after I made this post....DUH..
Wayne
M7 splitter
MSFITOY
Thanks for the detailed reply. I was already sold on M7 products after talking with Peter about several other products. I'm going to order the splitter. I too was concerned about how many attachment points were underneath and sounds like a quick call to Peter fixed that.
You have an awesome looking car. Congrats.
Hounddog
Hounddog
MSFITOY
Hounddog
Hounddog
Originally Posted by MSFITOY
Hi Hounddog,
Once again, hot car. Are you finished with it or are you planning to do anything else to it?
I'd have to see that one...hmmmn. I guess it ok as I don't believe the standoffs are under a great deal of stress. Peter has mentioned that he has done extensive, highspeed-120mph runs to Vegas and it held up like a champ.
Originally Posted by Darkness
I saw someone on the forum mount the standoffs to the grill on their MC. Is it ok to do this or is it a requirement that you drill into the facia?
I found his thread, here are some pics of his install:
more pictures are here if you need more:
https://www.northamericanmotoring.co...fiber+splitter
Is the length of the standoffs adjustable? If I installed it I would angle them a bit more and put them higher in the grill.
NO NO NO...This is totally wrong The standoff are designed for load under tension (vertical position). In this position, it serves as a HINGE If they were take a picture while at speed, the splitter will likely be deflected down as there is NO load support. To make the situation worse, it appears the splitter is mounted forward of the designed position. This presents a greater load area with fewer mechanical support. Unless this is just for show, it'll break very soon.
Hi everyone....
I'm glad to see everyone enjoying their splitter
The splitter was designed to give a fair amount of downforce at moderate to
high speed. With that said installing the stainless steel turnbuckles in an almost
horizontal possition (not recomended) will almost certainly guarantee failure
at high speed.
Have fun, and remember the speed limit is there to be broken.
peter
M7 Tuning
562-712-3270
www.m7tuning.com
at high speed.
peter
M7 Tuning
562-712-3270
www.m7tuning.com
M7 splitter
Originally Posted by M7
Hi everyone....
at high speed.
peter
M7 Tuning
562-712-3270
www.m7tuning.com
at high speed.
peter
M7 Tuning
562-712-3270
www.m7tuning.com
I too thought that installing the turnbuckles in a straight on fashion and into the grill wasn't the best option. I'm looking forward to getting mine and having it mounted on our new MCS.
Hounddog
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
ebowling
90
08-04-2019 09:15 AM
