Interior/Exterior replacing bulbs?
replacing bulbs?
I am looking to order an S by year's end. Anyway, I'd like to have my parking and fog lights match the Xenons I'd like to order for my new S.
If I wanted to replace the bulbs of the parking and fog lights with whiter lights, what should I use and can I replace them myself without disassembling the entire car?
Thanks.
Thanks.
Originally Posted by rataha
Front bumper cover has to come off to access the front fogs. Can't help you with your other questions. 7 screws as I recall
Plenty of info on bulb swaps on this site. Just do a search. Also, check out:
http://www.hoen-usa.com/
http://www.danielsternlighting.com/home.html
I used Sylvania Silverstars for the High Beams, and the Hoen Xenon Match for the Fogs. Also used the Silverstars for the front turn signals, no yellow shows through the clear lens.
Have Fun!!
Jim
Have Fun!!
Jim
Originally Posted by fs-mini
Actually, you don't have to remove the bumper to replace the fog light bulbs, I did mine by unscrewing about 4-5 screws from 'interior wheel arch', meaning inside the wheel wells. So, I did unmount the wheel first for better access, then removed those wall mounting screws, open it up and you will see the back of the bulb, just turn it and it will come loose. When finished, just put all the screws and the wheel back on. Finished in about 10 min. each side.
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
AZN Optics
08-21-2015 02:02 PM
