Interior/Exterior License Plate on front grill?
PKMINI-
Is the reason you don't want to put it on the bumper because you don't want to drill or you just don't like the look?
If you don't want to drill you don't have to. I affixed my euro plate frame using nylon zip ties. Check my site and click on pics.
I can get you some details picks of how to do this in a few days when I get my new aero bumper since the plate is off now and will have to be re-installed.
Chris
Chris
Originally Posted by PKMINI05
Can I attach the license plate on the lower black grill (below the bumper)? Will this affect oil or water or engine temps?
I don't want to put the plate on the bumper!
http://pg.photos.yahoo.com/ph/a1a@sb.../ph//my_photos
Easy to do, no drilling - just a couple of #8 screws (1 1/4" long) and related hardware. I use the factory license plate mount w/no mods. Essentially what I did was make two studs in the grill that the license plate mount attaches to.
It removes easily and if you use all black hardware the studs are pretty much invisible unless you're looking for them. As I said, I've seen no increase in the water temperature. It's only gotten up to 90 degrees in Dallas since I've had it on though (unusually cool weather - by now it's often knocking on 100).
/gary mc
I can't find my pic, but SCMCS has done a novel and elegant license plate installation on his car "Austin". The plate is supported by a bar that extends from his car's towing orifice. So it appears completely detached from the bodywork as though it were a sign describing the car as an exhibit. My description is hopelessly inadequate. Perhaps he will see this thread and post his own pic.
Front license mounting
I found the perfect solution for mounting the front plate and it has worked well for months:
1. Puchase the front plate bracket and frame (black or chrome) from the dealer.
2. Fully assemble bracket and frame with plate prior to mounting to vehicle.
3. Cover with protective material (original bracket envelope works well).
4. Firmly place under drivers seat of vehicle.
Justification: If you are driving in a manner such as to attract law enforcement attention, they'll never see the front of your car.
Originally Posted by GBMINI
Another option is to use the aero kit bracket, on the stock bumper - results in the plate being mounted below the chrome parts and looks better ...
Steve
In most states that require a front plate, as long as it's displayed on the front of the vehicle, it shouldn't be a problem...why not just wedge it in between the lower part of the windshield and the dashboard on the interior? I've done that with every car I've owned in many states that have required front plates, and it has never been a problem.
Dave.
Dave.
Dave.
Dave.
Oh yeah, that's a great idea. Just wait until you have to make a panic stop and the thing goes flying thru the cabin and takes off your passenger's head.
Dave.
Dave.
I've had my plates mounted like this since I got them. All summer in Dallas with no problem at all. Works great!
I have a few photos posted at
http://pg.photos.yahoo.com/ph/a1a@sb....net/my_photos
including a simple cutaway graphic.
Its funny but I just started a thread about a hour ago from this afternoons little project. It is very close to this topic.
Randy
m7 Tuning
https://www.northamericanmotoring.co...984#post629984
Randy
m7 Tuning
