Interior/Exterior Rear Fog Saga w/ Early 05 Models
Was perusing Gabe's site and noticed this in the how to section - http://www.motoringfile.com/files/2005_taillights.pdf - am I dumb but is there a part in this retrofit kit that will possibly help us early 05 owners who have an 05 with the rear fog added and have no wiring to accomodate the fog lamp?
The part number for retro fit kit is 63 21 0 309 436. There's got to be a part number out there for only the wiring harness - I just have to feel that this is the piece we need to make our rear fog work.
I believe the retrofit wire harness the only difference
between a early 2005 model, and those with September or October 04 build dates. I have an October 05 build and did not need the retrofit wire harness. just plug the lamp assembly in, snap the lens in, and twist the lamp assy into the back of the lens. (with of course 6 position switch and dealer programming )
Don't mean to hijack your thread - but I wonder if you need the January 05 build dates or later to get the bluetooth switches on the left spoke of the MFSW. I understand there is a switch assy that you can buy that comes with the replacement decorative cover so the two bluetooth buttons are on the steering wheel and not the odd black thing mounted to the center posts. I also assume the green led's are gone, and the steering wheel has orange lights consitant with the interior lighting.
rear fog
dude i added mine in 10 min its literally that easy. i did not want to bother with a switch because i was going to leave it on all the time anyway. but there are 2 wires that are connected to the side lights that are on the wheel well molding.i spliced 2 wires to them and connected the 2 wires to the fog light with some quick disconnect plugs. when i turn my lights on its on when i turn them off they are off. bam done. if you need more info send me a pm
The retrofit kit will not work.....it taps into the exisiting wiring harness for the light. There is no way to make it work. You can build your harness with the OEM Plug from the dealer. I have built four already and I am picking up 10 more plugs from the dealer and building more today. These harnesses plug right into the light and connect to the tail light plug.
Mike
I just went thru this at the dealer yesterday.
The exisiting kit is only available for the '05s with the wiring harness already present. I had told them that MINIUSA (based on a post I saw on here by HowardPM) had said something about releasing the kit for the early build '05s in June and they said that to date they have nothing on it. Actually they said, add 4 months onto June and that is when they might expect to see the parts available.
I'm just afraid that there are so few of us with the cars that are affected that they'll never release the parts.
Originally Posted by ZenAudio
Are you selling these? I have an August '04 build 2005 MCSC and am tired of that black piece of plastic
Mike
Mike
Here is the word from MINIUSA (as of today) about the OEM retrofit kit for the 7/1/04 - 10/14/04 (w/out wiring) rear-fog light.
Yes in July. The parts are already in the warehouse, only need a new
installation instruction. The bad news, the installation time will be
somewhere between 2-3 hrs. The additional wiring harness needs to be
routed from the A pillar to the rear bumper through the whole car. We
have checked several other options, but this is still the fastest and
most cost effective version.
So whoever said their dealer said $600 installed (a while back) is probably pretty close to what it will end up being.
Just thought I'd let you know for those that want to go the OEM route.
on
Hello guys:
How could I know if mine has all the wiring.
I bought mine (mcs 05) the 28th of May. (The car had just arrived that morning into the lot)
Does my car needs wiring or can I just install it without having to run all the cables throughout the car?
I just mentioned this to the dealer when I bought the car, and the service people gave me this scary scenario of having to rewire the whole thing.
(This was at UNIVERSAL MINI Los Angeles)
These people at this particular dealership make you feel like every job is an incredible pain in the ***!
Thanks for you help.
Originally Posted by fdavid
Hello guys:
I just called Mini ALexander and I believe my car is pre wired...they say it will take 2 to 3 ours of labor. I think I could do this job myself.
Does anyone have any DIY guide for this (images would be sweet!)
thanks again.
PS: Price: 196.00 for light and toggle button.
thanks again.
I bought the rear fog light from Global in Atlanta and when I pulled the black cover off the plug for the light was right there. It was taped to the harness. I untaped it and plugged it into the rear of the light then popped the red light in. The only thing for me is I want the light on when I turn on the switch, even without the lights on. I believe I'll probably end up cuttin the plug off the harness and wire it up independantly and put a momentary-off-on switch so I can flash people who ride my bumper. Any thoughts on wiring it up this way vs factory?? What has everyone else done. BTW my biuld date is 12-04 for a 05 mcs.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
Powershift
08-16-2015 05:14 PM
