Interior/Exterior Colored Tach and Speedo
#26
Originally Posted by Tarzan
Is that a model year change, or a different country spec? My 2005 USA-spec MCS only has 1 lamp for turn the turn signals.
Originally Posted by Cooper S IRE
Could you tell us in some detail how you did this did you print the bezel out on plastic after scanning in the original bezel also would you share the paintshop file????
-Josh
#28
Originally Posted by ahamos
Custom LED's? I smell a project...
that's my old miata in the pictures :P
#29
I just finished my custom colored tach. not terribly hard check it out and let me know what you think. (yellow doesn't look as good as i hoped) https://www.northamericanmotoring.co...0&ppuser=16230
#30
#32
#33
Needle removal.
I did a gauge face conversion on a Chevy S-10 a couple years ago and I used a fork to remove the needles. Worked really well and did not distort the needle. Realignment is criticle because your Speed will be off if it doesn't go back on exactly where it was. The speedo thing I think is called a potentiometer.(sp) I think, so alignment has to be exact.
[QUOTE=Battle Cattle]yea just stick a flathead screwdriver under it and it pops right off... first time its a bit harder than the rest...
#34
Looks great dude
I posted a while ago with my idea to create vinyl color colors for the gauges. I'm still working on making vector files so that i can give them to a sign company for the making. The numbers could be cut out and they would just stick right on top of the gauge face...things like checkers or Union jacks could be made as well sicne its just vinyl.
Keep up the great work
#35
Originally Posted by Battle Cattle
interesting... did you paint on the dial? If you didnt is that completely new or is it ontop of the factory one?
-Josh
-Josh
And the silver part is still on there behind the yellow transparency.
#36
No paint, I took took apart the tachometer, scanned the silver gauge background stuff, Deleted or erased all the numbers and areas I wanted to be able to show through, and printed it onto transperancy paper. It was fairly easy took me about 2hrs. and I'm not very good with the photo program. Just make sure if you scan it you have a colored piece of paper behind that way when it scans the image will be the size of a sheet of paper. This makes it so that when you print it out it is the right size. Probably some other ways to ensure correct scale, but like I said I'm no computer wiz.
Your best bet, short of paying someone, is to either live with the slight registration problems or hand-cut the gauges.
#37
The only way to ensure correct scale is to take it to a printing company. Printers, just like copiers, in the US are legally required to not produce 1:1 copies. This prevents successful counterfeiting. Plotters are not subject to this, nor are the commercial systems used by printing companies.
#38
Well my copy worked excellent maybe not 1:1 but 1:.999 if you do it right the scale will be correct. I only had to cut the outside circle nothing on the inside. The missed lines are my mistake in the computer program deleting too much. Not the printer. Maybe if you scan it then print not actually copy?
#39
If your talking about the double arrows I changed it because I think it looks cleaner than just an outline of an arrow.
I would rather not do it... plus the files are WAY to big to put up on the internet... I would maybe consider it on a person to person basis...
-Josh
-Josh
M7Speed
08-18-2015 05:18 AM
