Interior/Exterior How do I affix a badge?
No... i would not risk it.
What you can do is tape some masking tape around the area you
want the emblem to go and use the tape as your alignment to aim
your mark. :smile:
your mark. :smile:
Originally Posted by CARdiac
With the 3M headlight protection, I used a water-alcohol mix to help to prevent the adhesion until it was aligned well. Can this be done with the badge? Since I can't squeegee the hard badge I am assuming the answer is no.....
When I affixed a chrome John Cooper signature badge to my boot (opposite the standard Cooper badge), I put the piece in place very lightly at first so it just barely hung there. That way I could double & triple check alignment from every angle. Once I was absolutely sure I pressed it firmly into place and it's been fine ever since.
Nothing's worse than a badge that's just a tad bit off. (well, okay there are lot's of things worse, but you have to admit it's pretty bad.)
nismo4life
11-04-2015 09:18 PM
09-04-2015 11:43 AM
08-24-2015 02:18 PM
