Interior/Exterior (de)striping my mini...
I have removed three different sets of stripes from my MINI. Each was on for about 4 months.
You will probably see some difference right after you take them off, but keep in mind that the area under the stripe doesn't have the same amount of wax as the rest of the hood. Clean up the residue, then go about your normal process for waxing the hood. Once you do that, your paint should all be uniform.
My experience matches the others. I just peeled my stripes off with no tools but a fingernail (my own). There was a tiny bit of adhesive left at the top corners, but it came off easily with water and little clay bar rubbing. After my bonnet was waxed again, you wouldn't have know they were ever there.
Peel away!
Peel away!
Interior/Exterior Another hood stripe removal thread
broncobuddha
09-01-2015 06:32 PM
