Interior/Exterior Advice for aggressive-izing my front end
#27
Originally Posted by docross47
This is one of the nicest MCS's I have ever seen. I have an '05 JB/B MCS and I am just beginning to mod the car. I am taking my time like it seems you did too. It pays to be patient and do things the right way, this post shows what can be done in an incremental fashion.
It's been fun though...:smile:
#28
Well I was looking waaaaayyyyyy back on through the threads and I ran across this one. I figured it was fitting since I was planning on continuing my "De-Cuting" of my DS 2003 MINI MCS. The image below is the Photoshop version of what I am proposing. I have the lamps in place already..Actually they have been on the car since spring of 2004 (removed for winter) , I already have the CF front scoop and tow hook. What I am adding is a Racing Dynamics front spitter of which I will paint DS in with a graphic breakup I have not decided on yet. tinted headlamps and driving lights and "extending" the lower opening with a dark graphic to "widen" the car graphically without buying a new fascia. I'm going for the "halo" turn indicators. I had thought about graphics on the bonnet but after I PS it I decided not to. But I do have in mind some graphics for the exterior in a few spots. Actually they are already designed...Just have to send to the shop to be cut from my file.
I already have the car lowered with PIAA wheels, have white tail lamps, singele center exhaust and am adding a Uber wing.
Interior wise I have finally added some gauges. A SW boost gauge to the right of the tach and a SPA duel OT and OP in the right vent. Decided to cover the down tubes in Alacantra graphite and the door pulls will be added as soon as I have time. I added a Craven SSK along with the Silver plate to match the HK door trim. A new **** is on othe way from Bavarian Autosport. As we speak I'm adding low level blue ambient lighting. and I'm replacing all the yellowish interior lights with Xenon (more white) bulbs. Yes I know useless without pics. I'll take some when I'm closer to completion.
The quandry is I wish to add new seats....I've decided on Recaro Sportsters but jeez the cost! However this completed along with a fire extinguisher I'll be all set in the interior.....Yeah right!
Mechanically this year (and under bonnet)...A Wilwood BBK, A new belt, the Alta front rear control arm bushings, an Alta divertor (2.0???) I decided against a new IC...I am sort of on a budget! M7 Divertor, M7 Underbrace (hopefully), A engine dampener and other bits I probabaly forgot to mention.
Anyway...don't get on the forum much but I decided to share today....Maybe it's the weather. Great threads by the way!!! A wealth of information!
Both lower images about two years old...A few things have changed. About time to update me thinks....
#33
im planning this coming monday to black out my headlight inner housings. its called the joey mod. but im calling it the ive been to pu$$ to do it for about 3 months now and finally got some b@ll$ to do it MOD * for the PW ..( best color in my eyes ) i would go with the aero kit .....around 2k after painting and paint the wheel arches glossy black too ...maybe get some rims with a nice offset plack out your lights ...ur car will def be good looking oh and get some sort of sound coming from the bay....my alta intake was a nice lil upgrade for the price it was i def reccomend it
#38
#39
#42
#44
I don't want my PW/B MCS to be so darn cute, and am considering my options (listed from least expensive/complicated to most). Any advice for me?
Option 1: Change out my 04 chrome surround for the cleaner, simpler 05 chrome.
Option 2: Add the aero kit grilles (with painted surrounds).
Option 3: Add M7 Ultimate grilles.
Option 4: Add the whole aero kit front end.
Another option would be to paint your grille bars gloss black (to match the roof) and swap out your grille/upper bumper moldings for an 2005~2006 set.
Best of luck to you!
#45
"Badass" is relative. I'm running a monchrome...
... called it cute.
#46
on
The first thing I'm doing at the Dragon is rubbing vasoline on my hands and leaning on your car - no car should look so good.
I have to be content for the ralliesk look.
I hope they have a ding and scratch contest - I would be a contender.
#48
