Interior/Exterior Ram intake project
Old 02-14-2006, 05:46 AM
onasled's Avatar
onasled
onasled is offline
.......... here in New England the worst is in the spring when the frogs are coming alive. As they hop across the road, the M7 splitter ends up collecting assorted frog parts.
I also agree that a screen in a scoop is not a performance enhancer to say the least.
  #552
Old 02-14-2006, 08:24 AM
SumWon's Avatar
SumWon
SumWon is offline
Good find OldRick, let us know how it turns out.
Agreed, but realistically those who do more road time than track time, the decrease in long term IC efficiency caused by bugs trapped deep in the vanes of the IC vs. the short term decrease in air flow by a screen and the bugs temporarily trapped in it is acceptable. It is a real bugger (pun intended) to get those blasted things out of the IC!
I personally run a screen on the street, and then remove it before taking Bettie onto the track. Seems a fair compromise.
  #553
Old 02-14-2006, 09:21 AM
OldRick's Avatar
OldRick
OldRick is offline
I'm not at all sure that window screen, with maybe 60% openings, is not going to obstruct airflow more if laid directly on top of the IC, vs. a screen with much larger holes and 79% openings, inset in the scoop.
My guess is that changing direction 90 degrees and flowing through small holes in the IC itself is much more of an obstruction to air flow than the hood scoop opening facing the external air flow directly, so I'll put my screening on the less-obstructive part of the path.
And of course (I hate to admit to it) there's the bling factor of hex screen that echoes the cowl scoops.
  #554
Old 02-14-2006, 10:04 AM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
There's nothing wrong with "bling" OldRick I'm just relating my experience/testing...look at #1 post...the results achieved were with a screen on top of my IC. Prior to doing this, my old OEM IC was dented up badly from bugs and small gravel. To date, my Alta IC's fins are all straight and free of bugs...take it for what it's worth The best part is that no one looking at my IC in person noticed the screen...it is that fine...but it works
  #555
Old 02-14-2006, 12:39 PM
JCW Driver's Avatar
JCW Driver
JCW Driver is offline
The screen I have in my scoop just severs the bugs into a bunch of smaller more frustrating little bits...
I have not been a fan of it on my car for the aesthetics. I meant to paint it black to make it dissapear, or at least look sort of like the rest of the hexagonal grille work on the car.
The thing about the screen is that it is not the fact that it has a certain (and mathematically quantifiable) physical obstruction to the airflow, it's the inducing of a turbulent boundary layer of air around it, preventing flow that I assume would be the problem.
Just blow directly on your hand, and then put it behind a screen and do the same. You can feel the difference immediately.
The IC's are pretty sensitive in our little cars and I would imagine that the screen does in fact, make a noticable difference in IC temps.
For the time being, I'll leave my screen. At least until I buy that fancy, Sid developed, M7 scoop that this thread was about in the first place.
  #556
Old 02-14-2006, 04:19 PM
TheWrks's Avatar
TheWrks
TheWrks is offline
Coordinator :: Michigan MINI Motor Club
Just sent my M7 Scoop and Orciari Cowl Scoops to be painted BEP, should be ready Thursday
Will post photo's Friday night
Peter thanks fit is excellent
  #557
Old 02-14-2006, 06:22 PM
Partsman's Avatar
Partsman
Partsman is offline
Legion_of_Doom
Originally Posted by MSFITOY
Now you're giving my secrets away I've mentioned this so many times but no one listens:impatient
I've had a piece of screen sandwiched between my IC and diverter for sometime now, works great. What's that saying about great minds...
I also have a piece right up front, because around here when it gets warm out, we get bugs. There's no way you're gonna fit a blow gun back there to blow 'em all out!
  #558
Old 02-14-2006, 06:30 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
I like smart people...don't have to beat them over the head to see it my way
  #559
Old 02-15-2006, 03:46 AM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
Looking good Once I get my M7 Ram air scoop my Extreme scoop is coming out.
  #560
Old 02-15-2006, 04:14 AM
LauSai's Avatar
LauSai
LauSai is offline
Can anyone provide a shot from the side?
  #561
Old 02-15-2006, 04:27 AM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
Does this post help?
https://www.northamericanmotoring.co...&postcount=501
  #562
Old 02-15-2006, 05:02 AM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
Please go back and read through this thread...I know it's long but all the information/history/why/how are in there with many many pictures
Here's the prototype. Exactly the same as the production piece but without the exposed mounting hardware...
  #563
Old 02-15-2006, 07:16 AM
OldRick's Avatar
OldRick
OldRick is offline
Regarding window screen over the IC: has anyone measured the effect on intake air temp. compared to no screen?
How about the effect of coarse screening in the intake?
I'll certainly give up on the idea of honeycomb screen in the intake if it reduces cooling (after all my posts about big wheels, I couldn't possibly be seen going for appearance over function).
Second question about window screen over the IC: wouldn't aluminum window screen work better than plastic? It should increase heat "dispersion", to quote another thread...
  #564
Old 02-15-2006, 07:19 AM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
metal window screen has zero effect on efficiency...
  #565
Old 02-15-2006, 07:25 AM
TheWrks's Avatar
TheWrks
TheWrks is offline
I thought that this was a thread about the M7 Scoop developed by Sid and Joel , whats all this irrelevant talk about a screen that might keep out bugs.
  #566
Old 02-15-2006, 07:51 AM
fdavid's Avatar
fdavid
fdavid is offline
...wheres mine??? seems that everyone's got one already but me! Last time I spoke with Peter it was inthe mail (that was last week)..hopefully it will get here shortly.
  #567
Old 02-15-2006, 08:01 AM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
Fedex ground from CA to NY is about a week.
  #568
Old 02-15-2006, 04:30 PM
///ACS330Ci's Avatar
///ACS330Ci
///ACS330Ci is offline
Don't feel alone, I'm still waiting too
  #569
Old 02-16-2006, 11:27 AM
SCA's Avatar
SCA
SCA is offline
This is the only side shot on the thread and it is not of the finished product. I think that is what LauSai is looking for -- side shots of the actual final commercial product. I'd like to see some too.
  #570
Old 02-16-2006, 11:42 AM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
The only difference is the paint :impatient
  #571
Old 02-16-2006, 12:48 PM
fdavid's Avatar
fdavid
fdavid is offline
hmm. sure hope so because your prototype so far looks much sharper.
guys! side picks please!
  #572
Old 02-16-2006, 12:52 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
What is this?!?! Don't you guys believe me or what?:impatient :impatient :impatient
  #573
Old 02-16-2006, 01:24 PM
TheWrks's Avatar
TheWrks
TheWrks is offline
Friday night boys can you wait till then..
  #574
Old 02-16-2006, 02:09 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
Good Grief!!! Even you beat me to a finished piece :impatient
  #575
Old 02-16-2006, 03:03 PM
SCA's Avatar
SCA
SCA is offline
That'd be great.
As long as MSFIT thinks it's ok for us to see a side view, of course
Quick Reply: Interior/Exterior Ram intake project
