Interior/Exterior AeroKit Rear Bumper Sticker Removal??
Ok, I wasn't fast enough to tell the dealer to NOT install the vinyl sticker on the AeroKit rear bumper on the MCS I just picked up from them. So now I have that undesired look (for me) on an otherwise all black MINI.
How do I remove that sticker? What will I find underneath? This aerokit was ordered from the factory prepainted jet black, so I'm wondering if they would've painted the whole thing (seems it would be easier than masking the area for the sticker).
Once I get it off - and if it's not painted right - I'll just get some black vinyl stickers to put in its place (I saw an example of this on someone's blue MINI on another thread).
Thanks!
John
Thanks!
John
Well i dont know about your dealer but all the aerokit stuff including painting and sticking was done at the dealer. Unless there is something new about factory aerokits that I dont know about. So everything should be painted as to removing it... I have no idea and save the paint. Maybe someone else can help you there.
-Josh
PS make that baby black!!!
-Josh
Thanks!
John
Thanks!
John
john
on
I saw a cool sticker
Johnny at West Coast Mini/Johnny's Auto Clinic has the Jet Black Mini with Aero kit and he didn't like the sticker either. His wife came up with a decal to go over that area of the bumper and it looks real slick. He offered me one, I am sure he would do the same for you.
how about jus cuttin' it out around the sticker and adding M7's rear grill's to it it would make it a real functionin' bumper grill for air to pass out through it, and mayb help w/the dirt that builds up on the rear as soon as u wash it !?!?......:smile:
could be a little over the top, but would look killer! instead of all that sticker bull
Thanks!
John
Thanks!
John
I just removed the inset stickers from my MCS Aero Kit rear bumper. I replaced them with new Black w/White Dots inserts from CooperFlags.com. I was able to grab edges of the original stickers by using an Exacto knife and tweezers. Once I had enough to grab, I was able to just pull the stickers off. The stickers seem to be some sort of metallic material and are quite brittle. When pulling them off I found it best to use a minimum amount of angle (don't try to pull at 90 degrees from the surface). There was quite a bit of glue that remained on the bumper after the sticker removal. Spraying with Goo Gone, letting it soak in and wiping it away easily cleaned this. I then cleaned the area with Denatured Alcohol.
07-16-2020 12:54 PM
bctf1
08-06-2015 12:55 PM
