Interior/Exterior Unintentional Steering Wheel Center Cap Mod
Over the past 3 years my black center cap on my 2002 (2-spoke) steering wheel has become damaged. It is a bit cracked and dented and in need of some TLC.
According to the dealer, it is not an item that can be purchased by itself, only as a unit with the airbag for....*ahem* $408.
Has anyone had a similar issue? Would anyone know how to potentially repair it? I know it's a shot in the dark, but I thought I'd try.
Thanks,
-Loren
Thanks,
-Loren
They come up on eBay every once in awhile, don't know the legalities, if any, of shipping.
I've got a few spots on my 02 SW that could also use a touch up so I'm contemplating the repair. The airbag comes off relativley easy (2 screws hold the air bag assey on the steering wheel) so removing it to do some light sanding and a respray shouldn't be too tough. Don't think I'd want to do it while it's still mounted, due to the overspray.
RealOEM lists it for $254, have you checked with classic?
I've seen one before, but I think it was on one of the Japanese sites.
Originally Posted by Rick-Anderson
I've been waiting for somebody to come out with a chrome ring cover but I think the liability may be high since it is something that would lodge into your forehead if the airbag goes off!
It looks like the plastic center section is what's damaged, not the soft silver surround. The surround in my car lost some paint in spots, undoubtedly from fingernails and I found that Tamiya's Acrylic Bright Alumnium Paint (flat) was nearly a perfect match with the exception of sheen but a dab of clear gloss mixed in solved that problem as it made the paint semi-gloss. The stuff comes in small bottles at your local hobby shop and is around $3.00.
I'm afraid I don't have a solution for the center badge though.
Originally Posted by movieman
No, those are the horn area covers. They don't even have those for the MFSW.
Also, my MCS came with a custom "S" logo sticker over the rubbery center. Looked pretty good.
Maybe one of the many graphics vendors could come up with a decal/vinyl sticker for the center cap. I know that www.grafxwerks.com has a good selection of custom vinyl available.
Originally Posted by jeffroestobar
Ah, but they do. Here: http://www.mossmini.com/Shop/ViewPro...eIndexID=49566
Don't see the horn covers for MFSW. Did see the chrome ring around the airbag, though.
Man, I should be working for Moss or something. Commission maybe?
Thanks,
-Loren
Thanks,
-Loren
These horn covers? http://www.mossmini.com/Shop/ViewPro...eIndexID=45385
THe picture with all teh white spots on teh MINI logo looks like it is coming apart from teh inside. I remember one person saying the dealer fixed somethign similar as a warrantee item.
I had scratches on my center plastic piece that I buffed out in about 5 minutes time using some Meguiars Scratch-X and follwed up with NXT one day after I was done with a wax job. I literally was putting everything away and though, hey, maybe this will help. It probably took less than 5 minutes even and it looks about 95% of what it did when it was new, maybe like when the car was one month old rather than 2 years.
