Interior/Exterior Interior Dash
dash pad removal
The dash pad is easy enough to remove (4 screws).
Open both doors, remove plastic end caps on the side of dash, (they just clip on) pry them w a screw driver, just be gentle, also if you pull the rubber door seal out they come out easier.
Next you will need a torque screw driver (T20), remove 2 screws on each side off dash and after that its just a matter off popping it out, but do it gently, the dash kind of has to fold a bit on the center to clear gages abouve the steering wheel.
As for painting it....its vynil, so you should use vynil paint, check w your automotive paint store,
hope this helps.
hope this helps.
Hey guys, thanks again for the replies...The dash is vinyl? I thought it was plastic, thanks for the heads up. Are the other interior pieces vinyl as well, or are they plastic because I just bought some plastic spray paint from the hardware store...I can always exchange it though.
Will definetly post pictures when it's all done.
Originally Posted by eurokraft
the "dash pad" is vinyl, the other bits and pieces all around it are plastic, again, I'm assuming you are talking about the dash pad so.......vinyl paint is the way to go
got it
Ok I see what you whant to do, those are plastic, and its a bit more involving on the removal, not that hard but a few more screws and clips to remove, also beware that you have the airbag behind those plastic pieces, above the glove box, you should be carefull wen working around it.
The glove box will have to be removed also, along with the kick panel below the steering, etc etc.
Again, its not hard to remove but it takes pacience and time, good luck
I have the actual assembly drawings that I referred to when I removed and swapped mine out (on an '05). Removal is a little different on the earlier models but if you want the diagrams, let me know and I'll shoot you a PDF. My JB/W MCS started with an anthracite dash and doors but is now sporting CR dash and doors to tie in with the red/white/black custom bonnet, roof and boot graphics I added. Wasn't difficult to remove or replace any of the panels.
https://www.northamericanmotoring.co...29&postcount=2
Helped me do mine. Yes, gotta watch out for scratches. Use LOTS of clearcoat.
I used Vinyl-plastic paint on mine it came out nice.(see gallery) Several light coats. About 10 so you can still see the pebble texture on the dash.It was a semi gloss paint. From my local hardware store. Good luck don't forget the pics.
Originally Posted by skitelluride531
I will give it a try and see how it turns out. Thanks for your help.
'05/'06 Dash removal
Removal of the three dash pieces on an '05 and newer is a relatively simple task. The DS and PS pieces are held in place with friction clips. The center section is secured with friction clips and a couple of screws, and you have to remove the trim surrounding the vents and the two lighting buttons. There is no need to remove the vinyl dash cap on the newer models that have three dash panels (instead of the 5 panel earlier versions).
Since I still have the original '05 anthracite panels I swapped out, I'll take the removal instructions that I have (for '02-'04 models) and a few pics and create a simple "how-to" and post it here within the next couple of days.
It's a piece of cake to remove the downtubes on my October '04 MCC. Drop the knee bolster on DS, remove the two Torx screws on the left downtube, and then remove the two Torx screws that hold the cupholder in place on the PS downtube. Once the bottom of the center dash bezel has been lifted up/out, you should be able to tilt the top of the downtubes toward the rear of the car and just lift them out. :smile:
Something has changed on the later '05s and I haven't figured it out yet. My MCS is an August '05 build and the downtubes seem to be attached somwhere at/in the bottom console - can't get them out no matter how hard I've tried. Maybe someone else has had better luck getting them out of post- Jan '05 builds and can chime in here. It feels as if they are being held in place with adhesive tape and not with a fastener.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
patsum
26
05-29-2021 06:29 PM
