Interior/Exterior Photos of new fog and high beam bulbs vs stock
#26
Re: the post above - HID are not designed to shine 'blue' per see, the best project clear bright white light which illumintes the best. Some HIDs look blue and that is more of a cosmetic thing, but overall they are not designed to "project blue for better visibility".
The fact that a light is HID won't mean it works any worse in the fog or whatnot, it all depends on how the lamp projects light (narrow or wide dispersal) and the placement (high focus is bad in the fog and reflects on it, why the high beams are not good, and low wide projection works best).
#27
#28
okey dokey I was just out in the garage looking at the lighting setup for the front lights. The lights highlighted in the attachment are the ones I'm talking about. For the turn signal part I plan on getting ones from MossMINI that flash amber but are clear when off. There is a second bulb in this complex (if facing drivers side "complex" it's in the far right corner of it) that is on constantly when you are going down the road, what kind of bulb is this, and where can I find a replacement that is more of the pure white I am looking for? Also how do you replace the front High beams?
Mike
BTW I hope Rick Anderson didn't mind me using his car as an example, it was the only good frontal pic in my inventory that I could use.
Mike
#29
Took at look at this after your post - the manual states that it is a 5 watt bulb and from what I can find online it appears that it is the standard 5 watt 'wedge' bulb used in BMWs interior lights, etc. I can't be sure though since I am unable to remove it from the rear of the lamp and cannot see it clearly through the lens. Unless I find out otherwise I think the best way to access it is by removing the bumper. There are aftermarket 5 wat wedge bulbs (I played around with them in the E46) but I don't think any put out a great amount of light as they are only little 5 watt bulbs, so I do not know how much of an overall difference it will make.
I agree with you though, I would much prefer the 'driving lights' to be brighter and whiter light.
#30
#33
Originally Posted by fsuscotsman
Neat subject. Now for the silly question...how did you get the fogs to come on without the headlamps?
First click with 'parking lights' on, the fogs will work
By the way, DrDiff - glad to help I'll see if I can take any better photos of the yellow light projected, its kinda hard to capture but it is obvious when you have them on at night
And just fyi ChiliCooperS, I peeked over at Moss and the turn signal bulbs there are the same as the Silvervisions (I had a link to above) and/or the BMW stock silver painted amber light bulbs. The cheapest option is probably the BMW bulbs but I am not sure if they need any modification, I *think* that I heard that the base has an extra little bump on it that needs to be filed down - not sure though. I've had Silvervisions last for years and years before (the set in the MCS is actually off the E46 and had been on there a loooong time and are still going strong) so I can speak for their quality.
The super white fogs are on the way, looking forward to comparing them
#34
Oh, and just an on topic rant - it was raining and foggy and overcast yesterday and most people do not have any lights on I was driving along Waldo grade and there are dense patches of fog amist the rain, etc and you can't barely see all the seemingly grey cars as you approach or anything I was very thankful to have all the good lighting that I do have on the front and rear of the car - I knew they could see me at least!
#36
Welp, we finally got around to replacing the Yellow Ions with the SPP Super White bulbs in the fogs. The weather was awful and we didn't drive around with them yet so I can't provide any impressions from the driver's seat, but in looking at the car the bulbs do indeed look brighter and "go" with the xenons
Took some pics of the light projection comparison between the bulbs and you can really tell the difference:
Both Yellow
One Yellow, one OEM
One Yellow, one Super White
Both Super White
So the Supreme Power Parts fog bulbs both clearly put out more light then the stock bulbs which I am very happy about. I love the yellow light that the Yellow Ions project, but cosmetically I prefer how the Super Whites look when looking at the car. After driving with them in the rain and fog I'll let you know how I like them compared with the yellows from that perspective
SPP also says they have the little bulbs to replace the driving lights and I'm considering that too (I hate those dim off color lights) but on the other hand I am inclined to just be rid of those and have those lamps as just turn signals....
Both Yellow
One Yellow, one OEM
Both Super White
#41
Without coming off as a lighting expert, which I am not...
HID lights really don't "project blue" but the 'temperature' of the light is higher. Higher temperature light is closer to the UV end of the light spectrum and our eyes perceive it blue-tinted. Light color can be expressed in the Kelvin temperature scale. Tungsten lighting [unfiltered] is around 3500K and xenon lighting is close to 5000K [noon daylight is about 5500 K]. I think the reason that [high end] automobiles are going to xenon lamps is due to the higher [wattage to light] efficiency of xenon lamps compared to tungsten, not because of the color.
If the air is clear [low humidity], then high-temperature lighting if fine. If there's fog/haze/particulates in the air, then lower temperature [yellow-ish] light penetrates better because is doesn't get scattered. You want fog lights to penetrate and bounce off something other than what's suspended in the air. However, there is a quantity over quality factor -- 200 watts of blue light will beat a 5 watt yellow bulb...
I guess we ski with what we like, but blue tint is the last thing I would choose for a goggle/sunglass. Perhaps there is confusion about tinting and reflection here -- you can reflect blue light, perhaps with a thin metallic film that gives the goggles/glasses a blue chrome appearance, or filter out [absorb] blue light, with brown/yellow tinting, to give the same visual results to the wearer.
Can we agree that the folks who drive with either sunglasses on or tinted headlight covers are not 'cool'...?
-B
-B
Originally Posted by Zarrik
Actually, I have a pair of blue tint goggle lenses and a pair of orange tint. The blue tint is fantastic for overcast/shadowy weather, as it seems to enhance the amount of light. Unfortunately, you can't use the blue lense on a sunny day as it tends to magnify the amount of light that your eye sees. The orange lenses are better for sunny days.
I'm confused how a blue fog light is a bad thing if HID lights project blue for better visibility?
#42
#43
Thanks for the link -- a nice concise read. Now I know the correct reason why I prefer yellow fogs. Until reading the link below, I assumed it was due to less scattering, instead of the focusing and visual processing reasons given in the 'selective yellow' link.
However, running against the advice in the article, I have driven a few times where I felt that it would be beneficial to have both high beams and fogs on. Driving thru deer country on clear nights, it's nice to have a much light hitting the side of road as you can get.
And I've also driven [painfully slow] in heavy snows where the only way to safely see was to drive with [only] the parking lights on...
-B
-B
Originally Posted by chows4us
#46
What would Daniel Stern think of this lighting (brightest Xenon ever )
http://www.candlepowerforums.com/vb/...ad.php?t=92396
07-16-2020 12:54 PM
12-23-2015 10:36 AM
