Interior/Exterior Air Scoops
Hello MP....
You could get the Benfer ones: http://www.benferperformance.com/mai...uct=BFP-MCOWLS
I think Ociari (sp?) do the same sorts of scoops that aren't as big...
I was looking at AndrewH's mesh in his cowl vents (03 MCS) the other day - it's totally broken down and scrappy looking.... ..the 05' and later vents have a different type of material and grid pattern...
Also, if you take the scoops off you can actually open the scoop (it is two pieces held together by plastic tabs) and remove the foam. Then you can close it and put it back on. Looks fine, better than the ripped up foam. The holes are bigger but that doesnt matter unless you park under pine needles or something like that. I have had mine like this for a while with no problems, its a quick and easy fix.
09-10-2015 11:55 AM
