Interior/Exterior Valentine One Hardwire
hey m5vr6m3mcs
are thoughs the cars you own if so where do you live are the keys in the cars just joking well i have hard wird mine to my fuse box and that was no probablem i dont well are you going to have it on the glass at the top. mine is at the bottom sitting on the hump i think the rings it leaves are ugly but i have to switch mine out from my other car i drive tell me how it gos if you try it and good luck
Have not got my MINI yet, but I always hardwire it through a fuse (Fuse box) that is on when the ignition is on. This way your V! goes on with the ignition, automatically.
And you can just slide a "spade" connection in the fuse clip and push the fuse against it. Then find a bolt you can loosen that would serve as a ground.
Wohnson89
06-10-2020 04:53 AM
siriuszero
09-17-2015 04:41 AM
caiken
08-30-2015 05:34 PM
