Interior/Exterior license plate screw size
Hi guys:
I am looking for replacement for the stock plate screws. The guy at the dealer who installed both front and rear plated took away 2 of the 4 screw, because there dealer's frame has only the top 2 holes. Anyone knows what size are the screws? Thanks in advance.
The front uses a self-tapping screw that is commonly found in any parts store in the license plate frame display. The rear plate is held on by metric machine screws that thread into metal 'nuts' embedded in the plastic plate mount. Depending on whether or not you are using a frame around the plate that increases the overall thickness of the plate by an appreciable amount, you will have to get longer screws. Do note that if you get screws that are longer than necessary, they will thread too far into the plastic mounting and make contact with the painted metal surface of the hatch, scratching it and possibly causing corrosion. Generally, five turns or thereabouts of thread depth is all that is needed to properly mount the plate.
Screw size is 4mm by about 10mm stock. I added a plate frame and needed to use different screws, the originals were too small.
Originally Posted by MiniKJ
Thanks for all your help. I will try my luck first at the dealer before going to hardware store. I have to say though, this is strange that they use different size screws front and rear @
The stock rear plate screws are M5x0.8, about 8mm thread length. This should work with either a bare plate or a thin frame. If you use a thick frame, then you might need to step up to 10 or 12mm long screws. I just put stainless screws in my plate, and could only find 10mm at the hardware store so I just added a washer underneath each to keep them from sticking out the back too far.
09-11-2015 01:15 PM
