Interior/Exterior Finally dropped on H&R coilovers!
Old 04-10-2006, 01:56 PM
fj0's Avatar
fj0
fj0 is offline
Originally Posted by agile_moments
have you solved the wobble issue? was it getting an alignment?
pics don't do it justice, I'm sure it looks killer.
Partly because of this thread, I've decided on H&R's as well, hopefully I can post up some pictures soon,
but definately looking very good!
It's still shaking.
It seems that it happens in any gear from 0-30mph then it just disappears?(????)
  #27
Old 04-10-2006, 02:07 PM
flyboy2160's Avatar
flyboy2160
flyboy2160 is offline
that's how low i want mine! great looking car!
are these regular h&r's or club sport h&r's?
thanks
flyboy 2160
  #28
Old 04-10-2006, 02:37 PM
jerjer's Avatar
jerjer
jerjer is offline
Originally Posted by fj0
I appreciate the nice comments, thanks everybody!
I dropped it more and got an alignment today. My rear camber is over 2degrees.
Yeah, I need new front tires!
Useless pictures but you get it, I'll get some better ones when I have time.
is it just me or does ur front camber looks like postive camber instead of negative? i have absolutely no knowledge on these alignment stuff, is this normal?
  #29
Old 04-10-2006, 02:41 PM
VoiD's Avatar
VoiD
VoiD is offline
^^^^ I was thinking the same.
did you get an alignment compensating for driver's weight?
  #30
Old 04-10-2006, 04:16 PM
cooldaddy's Avatar
cooldaddy
cooldaddy is offline
looks sweet but you must have really good roads where you live...
  #31
Old 04-10-2006, 04:23 PM
MSFIT's Avatar
MSFIT
MSFIT is offline
looks good..but please describe the "wobble" or whatever you are having...
  #32
Old 04-10-2006, 04:47 PM
Kellzir's Avatar
Kellzir
Kellzir is offline
Maybe it could be due to bad front lower control arm bushings?
  #33
Old 04-10-2006, 04:52 PM
MSFIT's Avatar
MSFIT
MSFIT is offline
That is true, I just replace mine. Both were completely blown through. Much tighter drive now. I am just wondering if what you are going through is just because you have a lowered car..You kno that you stiffen things up a whole lot when you do that. My car has all kinds of vibrations/noises, rubbing in bumps, loud road noise, very stiff. Had to pull over one time cuz my friend got sick when driving a little bit on a windy/bumpy road. :P
  #34
Old 04-10-2006, 11:01 PM
skuzy's Avatar
skuzy
skuzy is offline
is the wobbling common with all coilovers or just the H&R's?
MSFIT what coilovers did u end up with?
  #35
Old 04-11-2006, 12:35 AM
fj0's Avatar
fj0
fj0 is offline
Wobble might not be the best way to explain them, shaking is more like it.
I'm experiencing shaking through the floor, accelerator and shift **** from ~0-30mph. It feels like it's coming from the front?
And about the ride being rougher, actually it's smoother now. I was surprised, I thought it'd be rough like crazy, but oh was I wrong. I mean it's not MB E-class but yeah. It's still rock solid!
Help!
  #36
Old 04-11-2006, 05:09 AM
agile_moments's Avatar
agile_moments
agile_moments is offline
I'm wondering if anyone else can chime in? Has anyone else experienced the vibration?
  #37
Old 04-11-2006, 06:34 AM
cooldaddy's Avatar
cooldaddy
yes, I got it after I installed the M7 springs which result in a 1.3" drop (approx). The wobble/shake is exactly as described below. After 10K it's still not quite gone but it's either getting better or I've gotten good at ignoring it...
  #38
Old 04-11-2006, 06:50 AM
MGCMAN's Avatar
MGCMAN
MGCMAN is offline
After a retorque and balancing, I'd check the bushings at each corner. The stock MINI bushings are a sort of neoprene like squishy rubber, not hard rubber nor polyurethane bushings mind you, but almost like a nerf football in consistency. They tend to deform and wear away with the suspension getting loose because of it. It might be worth it to have your car checked out by the dealer, they should be able to check if there is too much play due to bushing deterioration.
Also if you replace them, there are several ways to go: stock, poly, and maybe even hard rubber ('though I haven't seen hard rubber on the aftermarket yet). Search NAM for Powerflex and Mini-Madness threads on these bushings.
  #39
Old 04-11-2006, 07:01 AM
J0kER's Avatar
J0kER
J0kER is offline
is there a separate thread on this issue???
i thought there wuz but if not then a whole new thread might help to hunt down a solution.soon i hope, b4 i lower mine...
i hate shakes, rattles and/or wobbles
  #40
Old 04-11-2006, 08:17 AM
fj0's Avatar
fj0
fj0 is offline
Thanks, I'll look into it, how much money are we talking? For new bushings.
  #41
Old 04-11-2006, 08:48 AM
Logitex's Avatar
Logitex
Logitex is offline
He's running H&R springs.
  #42
Old 04-11-2006, 08:54 AM
ScuderiaMini's Avatar
ScuderiaMini
ScuderiaMini is offline
are you still alive?
it is a good idea
  #43
Old 04-11-2006, 04:43 PM
skuzy's Avatar
skuzy
skuzy is offline
so this shaking problem isnt due to alignment,tightening of nuts, bolts/ camber ?? but more so due to bushings wearing out? doesnt sound right to be honest.
  #44
Old 04-12-2006, 05:59 AM
J0kER's Avatar
J0kER
J0kER is offline
. ::alive & cruzn'
Originally Posted by ScuderiaMini
it is a good idea
dropnstylez
10-29-2015 08:57 AM
MR TJ
10-03-2015 01:22 AM
Ryan Caballo
09-10-2015 10:10 AM
RIchard Nguyen
09-06-2015 07:21 PM
Ryan Caballo
09-04-2015 12:20 PM
Quick Reply: Interior/Exterior Finally dropped on H&R coilovers!
