Interior/Exterior Front fog light removal for aero kit install?
You have to remove the plastic inner fender liner to access the fog light hardware. There are three or four screws and about seven 'pushpins' that look like large phillips head screws made of plastic. Look closely and you will see a ring surrounding the 'screw head'. There is a small notch in there. Push the blade of a small flat screwdriver into the slot while unscrewing the head. Once the pin is unscrewed and removed, pry out the outer pin piece. There is a screw under the air dam and one under the rocker panel as well as the few visible in the wheelwell.
Depending on if you are adding the aero kit to a MC, you might have to 'relocate' the lights to the position used on a MCS. Torx screws hold the lights in, and clip nuts are used on the mounting frame.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
08-07-2015 05:55 AM
