Interior/Exterior New Lights Part Deux
Originally Posted by Duck360198
Hella Black Magic...so freakin' sweet! I would love to see more closer up pics and see how you installed those. Also, where'd you put the switches for them? Looks stunning and I want to do the exact same thing when I get my DS/B in a couple weeks.
BTW: I used 4 outmotoring mounts which were a breeze to install! I did have the Alta bar, but could only fit 2 lights on it because it designed for 6" lights not 7". The other reason I made the change was because he IPF lights were just toooo chromey and the Black Magics fit much better with my theme.
Also, be prepared... this light mod is a little pricey
Brackets: $300
Black Magics: $500
Originally Posted by swarley
I'll post some better pics when I finish moving the switches. I'm still debating on whether or not to leave them on the left of my parcel shelf or to bring them between the seats and mount them on either side of the mirror control.
Brackets: $300
Black Magics: $500
Brackets: $300
Black Magics: $500
Finally, how can you aim these? Up and down? Side to side? Are they fixed?
Looks incredible man!!!!
Looks real good! I'm running the same brackets, different lights.
I put the switches on the ends of the console panel where the mirror control is and they fit fine with some minor reshaping of some ribbing on the back of the plastic panel. I think that location is where the switches for the heated seats go. Might be interesting to pick up a couple of seat heat switches and repurpose them.
To answer the other question; the light will adjust side to side quite a bit and the up and down will adjust about 1/4 past the verticle before it rubs on the bumber.
Here is where I ended up putting the switches;
More Pics; http://www.myminionline.com/gallery/hella4/
