Interior/Exterior Exhaust Idea!!!
I just did a custom "one-ball" with a flange that lets me replace the stock muffler with a 2.5" race muffler.
The race muffler (dynomax magnum race bullet) is way too loud ... even for track day use only. Deep and mean sounding, but super loud.
I would suggest using a resonator, and a larger muffler to help quiet it down.
Originally Posted by prime-drk-
from what i have read running mini's without cat's isn't such a great idea. It seems that the mini's ecu actually takes samples post cat so if you remove it you are going to end up with your ecu running improporly.
Something to look into.
erik
erik
My personal experience confirms this (I have run without a cat, and there's no detrimental impact on the engine managment.)
cheers,
i hear what you are saying and im sure that from your research you have proven that there is no harm in your case. however I was kinda basing my info on what Randy had posted on this link.
http://store.webbmotorsports.com/ind...b9d916f83d7b00
If you scroll down to the last paragraph you will see this.
Quote From The FAQ from Webbmotorsports.com.
Why do you only use headers that have a catalytic converter?
Because I care for the environment - just kidding (not that there's anything wrong with that).
This question goes to how the MINI determines the A/F (Air/Fuel) ratio. There are two basic functional modes the ECU: open loop and closed loop. Closed loop is your friend, as it uses real time, actual fuel burn to determine the A/F ratio. This is determined through the O2 sensors, located in the header. The spent combustiable mixture passes out of the cylinder head and into the exhaust system. The O2 sensors can tell the ECU what the fuel ratio was, and the ECU trims accordingly to maintain the desired ratio. OBDII (On Board Diagnostics II) uses the O2 sensors to monitor catalyst efficiency.
Open loop is used when the O2 sensors can no longer handle the flow rate. This is pretty acuurately described as a "best guess" A/F determination. It is a very accurate guess, but real time data is always the best.
The MINI has two O2 sensors, one pre-cat and one post-cat. The sensors measure the temp difference and convert it to voltage, which is monitored by the ECU. Because of the OBDII, it needs to be sure the cat is functional. If there is no change in voltage, the O2 sensor assumes it has failed and the ECU functions in open loop.
So, the reason I use only cat-equipped headers is so I don't lose the accurate closed loop ECU function.
erik
erik
And it will be loud and annoying, just running without the cat made it hella loud and noisy. If you want to sound like a Civic, go for it!
Randy's post says nothing about the role of the second o2 sensor--and as TampaMCS says, it's the first (pre-cat) sensor that tells the ECU how to adjust the A/F. The second, post-cat sensor does what I said, which has nothing to do with open, or closed-loop operation and A/F.
And just for the record--although "sound" seems subjective, when running cat-less, my MCS sounds nothing like a Civic Ricer. I actually heard a Subaru WRX-STI and a Mitsubishi Evo going after it recently, and I could easily have joined in the chorus and been in tune. I don't think these cars are what people think of as Ricers...nor is a MINI, stock or modified.
cheers,
cheers,
My car sounds meaner and deeper than any 4 banger ive ever heard.
Originally Posted by sandtoast500
I'd like to do a custom header into a straight side exit next to the wheel well. Maybe then people will pay attention to me.
08-12-2015 01:24 PM
