Interior/Exterior Viper Stripes...need photoshop help
on
Hi, I currently have the "U" stripe on my MINI. Im interested in silver Viper stripes to match my roof and Im fairly confident it should look good on my MINI but I need someones expertise in photoshop to convince me 100%
Thanks in advance
Opinions if I should do it would be appreciated too.
Thanks in advance
Again, not the same thing, but here's a guy with a white roof and contrasting stripes: https://www.northamericanmotoring.co...0&ppuser=15213
on
Originally Posted by garretwp
Did you have trouble getting the stripes to stick to the textures plastic at the bottom of the bumpers?
- Garrett
- Garrett
Yeah, it was tricky.. but it seems to be sticking this time around. My previous set had a couple corners pulling up. The surface needs to be completely free of ANY dirt/grime/oil. Alcohol is probably best to remove any contaminents.
I found that after applying them, using a hair dryer to heat the adhesive up helped a lot in getting them to stick. You've got to get the vinyl nice and warm and use your hands to work it onto the textured plastic as it cooled and hardned. Very time consuming but it does make a difference. One more thing.. I didn't do, but wish I did, was wrap the vinyl completely around to the back side of the plastic so it won't be prone to lifting at the exposed corners. The plastic on the back side of the textured portion is smoothe which is much more sticky-vinyl friendly. You'll have to push back the stock plastic mesh grill to get to the other side effectively.
The funny thing is.. I'm very close to taking them off, despite the tons of hours I put into applying them a couple months ago.. It's time for a different look..
Hope this helps!
Originally Posted by Pir8 97
Here's a pic of my car w/ grey stripes... not exactly the same but you get the idea
hey swarley where did u get the carbon fiber eye rings? thanks
Originally Posted by ayyado
love your car exactly what i want my car too look like, but would it look the same on non s type or should i get a new type S hood first i think it adds a meaner look ......anyway looks great
Just my 2 cents, but I'd advise against putting the S hood on a MC. It could come across as
O4mcs
08-06-2015 05:42 AM
antsmini
50
07-15-2003 10:46 AM
