Interior/Exterior Hardwire Issue
Hardwire Issue
I hardwired my XM radio into my MINI yestarday. Apparently I did something incorrectly. It turns on and works, but then turns off every 20 seconds, and then turns back on and continues playing...this continues in a cycle. It seems to happen when I hit bumps in the road, but I could not confirm if this was related to the problem.
Here is how I wired it:
Add a circuit into #36 slot
Split the power wire for the radio in two (+ and - I guess? )
Ran one of the wires to a ground - one of the bolts up around the pedals
Ran the other into the Add a circuit.
Then I ran the wires around the car to get to where I wanted to mount the radio.
Did I do something wrong? This is waht the guy at radio shack told me to do...so I am kind of confused?
Alright thanks!
Alright thanks!
Are you using a Roady XT? I have found that the mount for the unit does not adequately hold the unit in place and over bumps the head unit becomes disconnected from the base. Still trying to figure out a way to permanently secure it so it doesn't jostle loose. I used 2 rubber bands on the way to FLA and back before in a pinch. Looked cheesy, but worked.
Originally Posted by GBMINI
It's easy to see if it's related to bumps - just park and keep listening!
If bumps cause trouble, you have bad connections to solve, but it it keeps cutting out when you're parked, you have a different issue ... figure the problem then figure the solution!
I am not clever enough to think of that . I will try that and see.
I am not using the Roady XT, but the mount that came with my radio (Audiovox XCS9) makes the radio seem a little loose as well, so I will have to do so configuring today
put some e-tape on the inside portion to make it a snug fit. Give that
a shot and let us know how it goes.
I think you did the add-a-circuit correctly. Im not sure if there's a
fuse there that goes on/off intermittently.
Hey guys,
I tested it out this morning. It was fine while I was sitting in my garage for 5 minutes, but just as I thought, as soon as I got on the road it started turning on and off again.
The good thing is, I think I know where the problem is, so after I am finished waxing my MINI I am going to hopefully fix it .
Another thing to be careful about...many of the radios do not actually run on 12v; they have electronics in their lighter plug that reduce them to 6v or whatever they take. In which case you are overpowering your satellite radio and risk frying it (you're lucky if it's just turning off...). A solution is to direct wire a hidden cigarette lighter socket (available at radioshack etc) and then you can plug it in to that.
Wohnson89
06-10-2020 04:53 AM
siriuszero
09-17-2015 04:41 AM
09-01-2015 04:02 PM
caiken
08-30-2015 05:34 PM
