Interior/Exterior How long to wait before installing badge over boot stripes?
I'm ready to install my DIY boot stripes from Aesthetic Creations and I was wondering how long I should wait after the install before reinstalling the Cooper S badge.
And a follow up question of how long before the vinyl can withstand a Z7/Z5/Z6/Z2/Z6... treatment.
Thanks.
Thanks.
Thanks.
Thanks.
It took me about an hour. I was extremely nervous that I'd mess it up but it proved to be pretty simple. It started getting dark so I didn't feel comfortable putting the replacement CooperS badge back on so I'll do that tomorrow.
The Aesthetic Creations instructions were very helpful and the DYI stripes thread also cleared up some questions I had: https://www.northamericanmotoring.co...ad.php?t=73509
I used the 'dry' technique outlined in the AC directions although others have mentioned using a slightly soapy solution that is supposed to reduce air bubbles and allow for some slight movement if you get a crease or fold. The dry technique worked fine for me.
After viewing some images on NAM I decided where I wanted the stripes (left to right) so that the badge would land with the C fully in the black rather than partially in the white. Then I removed the badge with dental floss and cleaned up the adhesive with alcohol. I then washed and dried the boot where the stripes would be placed to remove all Zaino and to provide a good base for the vinyl. I taped the stripe in place and double checked my measurements.
I then peeled back the stripe from the top and removed the top half of the backing and started working very slowly up the vinyl keeping it with a soft curve up and away from the boot. I found that if you pulled very tightly on the vinyl it tended to crease severely around the rubber squeegee making it susceptible to wrinkling. For me, a soft curve to the vinyl while working slowly seemed to work best.
Then I peeled the backing off the bottom half and repeated the slow march to the bottom edge of the boot.
Rinse, lather, and repeat on the other side and I'm done (minus the badge replacement which I'll do tomorrow).
Originally Posted by Crashton
Could you tell us where you found that flags badge? Very nice.
07-16-2020 12:54 PM
squawSkiBum
10-02-2015 09:21 AM
speedbird_1
08-15-2015 04:44 PM
