Interior/Exterior After market skid plate, necessary????
Old 03-28-2003, 07:13 PM
rrmixn's Avatar
rrmixn
rrmixn is offline
Why hasn't someone built a skid plate out of aluminun? It seems to be strong enough for the off road trucks but the only ones we can get are heavy steel or stainless.I would think it would be plenty tough and much lighter and much less expensive than a composite. By the way, does that mean carbon fiber,kevlar, or fiberglass?
  #27
Old 03-30-2003, 08:25 PM
PDX_Mini's Avatar
PDX_Mini
PDX_Mini is offline
Any diff in weight between the stainless and black? I'd like to go stainless but if you can't see it what's the point?
_________________
  #28
Old 03-31-2003, 11:24 PM
ryhtomit's Avatar
ryhtomit
ryhtomit is offline
I put a small piece of wire mesh in front of the fan and attached it to the fan body with 3 rivets, works great!
  #29
Old 03-31-2003, 11:29 PM
beshaw's Avatar
beshaw
beshaw is offline
exactly what i'm going to do, quite like industrial computer housing fan guards.
super job :smile:
  #30
Old 04-01-2003, 07:30 PM
SB's Avatar
SB
SB is offline
Is the main concern with protecting the fan the fan itself? Or is it just to keep stuff from stopping the blades. If it's just about keeping the blades free of debris then that computer fan grill sounds like a good idea. For some reason I was under the impression that the whole fan, housing, needed to be protected because it was plastic.
  #31
Old 04-02-2003, 09:52 AM
chrisneal's Avatar
chrisneal
chrisneal is offline
>>Is the main concern with protecting the fan the fan itself? Or is it just to keep stuff from stopping the blades. If it's just about keeping the blades free of debris then that computer fan grill sounds like a good idea. For some reason I was under the impression that the whole fan, housing, needed to be protected because it was plastic. <<
I think it's probably best to protect the whole thing, not just the opening. I'm thinking about snow here - seems like if you're driving through 4 or 5 inches of snow, the opening of the power steering fan could clog up. As far as the durability of the whole plastic fan assembly if you run over a piece of debris or something, I have no idea...
  #32
Old 04-14-2003, 07:20 AM
MGCMAN's Avatar
MGCMAN
MGCMAN is offline
Added the Moss powder-coated skid plate this week-end. fifteen minute one person job, weighs some 25 lbs or more though. Couldn't justify the additional $$ for stainless that will only be viewed for a split-second by road kill (before the fact). IMHO a worthwhile investment, especially when viewed with the plastic crap MINI uses for OE.
  #33
Old 04-14-2003, 07:35 AM
Misfit's Avatar
Misfit
Misfit is offline
what about doing this. i did this to my vw. i took a metal skid plate. drilled a few holes in it about a inch big. i did 5 over the entire plate. this alloud for air to go in and nothing bigger than a inch. it had to be quite well placed for this to go through. nothing has gone in cept soem water and dust and the occasional mud. no more heat issues for that.
veevsato
09-15-2015 06:04 AM
09-11-2015 01:15 PM
09-04-2015 12:30 PM
09-03-2015 02:06 PM
Suspension Products
09-02-2015 10:32 AM
Quick Reply: Interior/Exterior After market skid plate, necessary????
