Interior/Exterior Yet Another DIY Intercooler Screen
#77
on
Originally Posted by Funk_Flex
I stopped by my local Home Depot and they only sell the gutter grill in packs of 3. What am I gonna do with all the extra material . So I just ordered one from Kenchan.
Here's the result :
#78
#79
^^ there is some minor play, but it shouldn't be so loose that it would
move around. the scoop is plastic so it won't rust, but if you're real
****, you can wrap some e-tape on the scoop's lip from the inside
(diverter side) and protect it that way.
i just left mine alone and installed the grill.
#80
#81
This how-to is for any one who would like to use it. It is not the best, but it gets the job done.
First lay out your tools. You will need:
8mm Socket
Phillips Screw driver/Drill
The pre-cut grille
Some kind of container for the nuts/screws is recommended
Oh, and your MINI.
Second, open the bonnet and locate the 8mm nut on the under side of the hood. There is one on each side. Remove them both.
Third, locate the philips screw about 18'' down from the nut you just removed. There is 1 on each side. Remove them both.
After both nuts and both screws are removed, the...well....rear of the hood scoop will fall right out.
Take a look at the opening in the scoop. There is a little ledge that will hold the grille.
Grab you pre-cut grill, and pop it in! It doesnt have to be REALLY snug, just "in there."
After its in, just re-install! After you're done, it should look like this:
8mm Socket
The pre-cut grille
Oh, and your MINI.
#82
#83
Bruce, the towel idea is a very good one that I use.
I wouldn't worry about it comming loose. Even if it does, I doubt it will go anywhere.
But....Worst case scenario, a boulder pushes it into the engine bay. I dont think it has room to effect anything. It might restrict some airflow over the IC, but thats it.
#89
Originally Posted by kenchan
^^ hey looks good! thanks again.
I used the ratchet to loosen the 8mm nut but I tightened it by hand. With the socket and extension piece of course. I was afraid of stripping the nut if I used the ratchet. Anybody have problems with the nut loosening up over time? How about the screw?
#90
#91
No, thank you
i recommend retorquing the nut when you check your oil level, etc.
as ive seen some cars with those nuts missing (fell off).
but the phillips screws, don't over tighten. the holes will strip very
easily.
#92
Originally Posted by trackster
Those certainly do have a finished look to them. Any idea as to what amount of intake reduction is occuring due to the restriction ? On a side note how the hell are you guys selling on NAM without a vendor agreement LOL .
air flow loss.
i sold it in the market place...but only a small handful. i don't have
enough time to mass produce it like if i was selling at a shop commercially.
it was fun though and i enjoyed making them. it's very cool to see the
picts.
#93
IQRaceworks
53
06-28-2024 07:29 AM
OutMotoring
09-08-2015 06:27 AM
