Interior/Exterior Speaker replacement:Need advice/help
Hi,
I've replaced the stock speakers of my S with some Polk's. They all sound pretty good but the front speakers are operating at nearly 1/2 the volume of the rear 6x9's. When I replaced the component speakers there were 4 leads running a full signal (one to each tweeter and 6 1/2" speaker) with two having a high pass filter at the connector for the tweeters up by the handle. Since I only needed one lead per side to feed the crossover of the polks, I took them from the lead to the 6 1/2" speakers. I'm getting a full range sound but the volume is about 1/2 of what the rears are. It can be adjusted with the fader control but that doesn't actually fix the situation.
Any thoughts?
Regards,
Mike
Any thoughts?
Regards,
Mike
The mmc690's have a sensitivity of 91, the DB690's are 93.
You'd think the DB6500's (92) and the MMC690's (93) would be pretty evenly
matched in terms of efficiency/loudness.
Not sure why they're not. Make sure the fronts are in phase with the rears,
and double check the wiring. Maybe the acoustics of the car interior plays
a role as well.
a role as well.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
RobbyD
01-29-2019 01:22 PM
gar56
11-15-2016 06:41 AM
patsum
10-01-2015 06:33 AM
