Interior/Exterior Long silver antenna and/or bezel.
I like the length of the Mini antenna.....not interested in a stubby. It looks fine in black, but I have an all dark silver MCS and would like to find a silver/aluminum antenna that can be extended to at least 10". A silver bezel that fits an '06 would be super too. Do these things exist?
FD adjustable length antenna
Aluminum FD billet antenna to replace the OE black antenna on Audi and VW. Comes complete with 3 black masts so you can select the height most interesting to you; options are approximately 5" 6 1/2" and 10 3/4" tall. The kit includes two mounting studs to cover most applications: 5 mm and 6 mm diameter. Slight reception loss in certain areas is possible however for the most part reception loss is not noticed
Short stick aluminum antenna fits VW and Audi models with factory roof mount antenna. 6.5" tall with two aluminum sections bottom 3" top 1.25". Includes 6mm threaded adapter to install on Audi antenna bases.
Yes... the threading fits the mini.
ECS tuning.... if ordering... Phone it in!!!!
There should be alternative sources also
07-16-2020 12:54 PM
08-24-2015 02:09 PM
