Interior/Exterior Aero Grille Install...
Hey guys, I just received my grille from Mini Mania, and I'm having a little trouble getting it on. I can't seem to get the nuts to unscrew from the factory grille, even though I am applying some pressure behind them to ease them out while I unscrew.
Does anyone have any suggestions as to why they are difficult to come off, or maybe an easier way to take them off.
Any help would be appreciated.
I'm actually going to be working under the assumption that I will be snapping some of them, but just to be clear, the fasteners look like little nuts with washers with a plastic "bolt" screwed into them right?
So it looks like I will most likely be going to the dealer to pick up some extra fasteners for the inevitable snapping that will occur! lol
I just installed the aero grill, upper was pretty easy...Except for those dang nuts...what's up with those??? Anyhow when I put the middle one in after cutting new slots for it, it does not fit flush with the bumper on the outer edges and on the lower part of the bumper as well..will I need to remove it and do more cutting to make it sit flush all the way around? Please help!! Thanks....Jerry
Yes you need to cut between 1/4 and 1/2 an inch off all the way around. Theres a pdf with some pretty good instructions floating around here somewhere. I used it when I installed mine but I deleted it from my comp when I finished.
I trimmed off the excess material on the lower grill just like the directions said..It went very well using my Dremel tool.I tried a dry fit and it looks great..Just one more question, It still sticks out a bit on the bottom edge..I was wondering if I should remove the piece that protrudes out from the bumper..It looks like the new grill hits it and is keeping it from laying flat..Thanks for your help...Jerry
TRuTH, I wish I could send a picture but my camera is ooc..I will try to discribe what I was talking about..My car has the chrome trim and the strip that was attached with double stick tape was the part I was asking about. It was attached to a curved louver thingy and it sticks out a bit. It hits the back of the new aero grill...
This is the piece in the lower(smaller grill piece). What I did was cut (dremel tool) this piece off. However if you do this you can see the steel bumper behind it. What I did here was when the plastic bumper was off, I painted the steel bumper with black spray paint (I used high temp BBQ, cause I had some laying around) it looks really good. My wife has the car for the day but if you want a picture I can take one tonight.
Todd
Todd
gar56
11-15-2016 06:41 AM
