Interior/Exterior Connecting driving lights switch to low beam?
you can just wire the trigger to your low beam wires, but as
chows mentioned, dont use them in traffic as you WILL blind
oncoming traffic.
i wired my trigger to a switched fuse so i can turn it on
when the key is in the on position. but i don't use the driving
lights unless i really need it in the pitch dark rural areas.
oncoming traffic.
so, any idea which wire is for low beam?
oncoming traffic.
oncoming traffic.
It will be the other large gauged wire in the connector. They are different between model years and between left and right lights. Have a multimeter or a test light, easy to figure out.
Having given you the "power" don't misuse it. Nothing bothers us more then getting the crap blinded out of you while driving these back roads. We get enough of that from the Saturn drivers
That's what I did, so I can turn the switch one whenever. The PIAAs I have I turn on with the Xenon low beams and the color of light produced is much better than with the "yellow" light from the high beams in there, too. But, as mentioned, I only use them out in the pitch-black rural areas, they aren't for everyday use as much as I would like them to be...
Yup... as others have said "don't do it". Only kidding because I have mine
wired up that way too.
With that out of the way, go to Sears / Radio Shack / etc and get a cheap automobile circuit test light thing. That way you'll know for sure. And it just may end up coming in handy at some other time too.
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
12-23-2015 10:36 AM
ryGuyMCS
10-20-2015 02:24 PM
