Interior/Exterior blowdryer to take out bubbles on a sticker
on
If the sticker's a little older, a blowdryer on "low", and held several inches away, will soften the decal enough for the sharp-pin method to work. You don't need hellacious heat, just enough to soften the decal. You should be able to hold your hand under the hair dryer at decal level - or just leave the car in the sun a while. If the bubble is near the edge and the decal fresh, the "lift" method also works. Lifting a heated decal, though, will stretch it and it won't re-form.
RobbyD
01-29-2019 01:22 PM
