Is there any easy way to remove the driving lights??
The reason is: Im replacing my front grille and of course, I already have the driving lights installed. I dont want to cut the wires and have to reinstall them again thru the lights. Is there an easier way to remove them?:impatient
No easy way. I took the lights apart and removed the wires from the inside, but I did have to cut a wire since the end wouldn't fit through the hole. You'll also have to drill out the rivits on the brackets or mutilate the old grille to get it off.
The dealership install has the black brackets riveted to the underside of the bonnet. If you have screws, you either had a "non-standard" installation or they weren't installed by a dealership.
