Interior/Exterior M7 Splitter Durability/Impressions
#26
It looks like something like THIS would work, if I can find the proper peice to attach to the fender and splitter (the peices that the ends of this would attach to):
#27
Thenks MSFITOY!
Does anyone know if the turnbuckes can be had as a seperate componant from anyplace? I'm honestly torn between this unit and the one that StoopidGirl's selling over in the Marketplace forum - problem is I like her unit's looks better but it doesn't have the cool support peices.
look how cool....even in matching CF
www.ecstuning.com carries these (they are even an ohio company)
#28
I have a set of these but found them too short (needs another inch)
#29
#30
Can you send a link to the product page for these, please? I can only search by vehicle on ECS Tuning's site and I'm not sure where you found these... Also, how much do they cost? The all-metal marine ones are really, really expensive...
And yeah, I was thinking about fitting these to THIS SPLITTER that StoopidGirl's offering - I like the up-curling ends. Since these do not have standoffs, I assume that they don't need them.
EDIT: Never mind - found them. They make a 45mm and a 70mm version - the 45mm ones were too short MSFITOY or did you try the 70mm ones? ?
The only challenge I see in installing these is fitting them to the splitter itself. You can take the fender peice off to fit the nut/bolt, but how would you do it to the spitter peice? Hmmmmmmmmm.... Maybe the M7 one is the better way to go... I dunno. ::: ponder :::
#31
Just another word of caution...and remember I told you so, but...You're gonna rip that spoiler right off in the first month No matter how careful you are, you're going to scrape going up steep driveways with that thing hanging down and any road kill you encounter will ruin your day...
Stick with M7...
Stick with M7...
#32
I thought it only hung down a little way past the part that dangles under the bumper as it is. There's a vertical "lip" under there that hangs down a few incches as it is. People seem of multiple opinions about the possibility of losing this to road debris. Honestly the main appeal of the non-M7 one (besides the upturned ends) is the fact that you DON'T need stand-offs with it. I'd sort of like to install it for a few weeks with no supports and see how I like it, since once I drill holes for the stand-offs then there's no reversing it.
#33
#37
What I noticed with the Hamman and its clones is that when looking down from directly obove they hardley protude at all into the air stream. They may pick up something on the ends but the middle isn't doing much. This of course matters only if you are looking to get any real benefit downforce wise for track use .
#38
The function of a splitter is to "split" the high pressure air flow from above and below the plane of the splitter...it functions optimally at 0 degree attack angle forcing high pressure air above it to travel the long route over/around the front end...effectively piling up on top of the splitter...the portion below speeds along the bottom of the car...the high pressure air at the front/top exerts downforce on the front end of the vehicle...
That said, M7's splitter does what a splitter is suppose to do...I'm not trying to sell one...many people have built their own splitters because the principle is so simple yet so effective...if I were to improve on this design, I would extend the lip another inch and rearward to cover the bottom of the motor...the standoff's primary function is to keep the splitter level and support the weight of the high pressure...not for adjusting angle of attack...if you force the splitter to tip down, you have effectively transformed the design 30 years back into the "air dam"... The reason the "splitter" is more effective than the obsolete "air dam" is it does not cause parasitic drag...
Moving on to the Hamman knock offs...it is neither a good splitter nor a good air dam...it causes drag...is prone to damage...it is primarily a show piece that "looks" like it will serve something more useful in 2F2F...IMDO...
#41
OOPS sorry didn't want to start THAT discussion again
#42
#43
Wohnson89
06-10-2020 04:53 AM
ebowling
90
08-04-2019 09:15 AM
