Interior/Exterior Need a betatester for our downtube covers
#102
Girl Power! OK.. that was pretty easy. Took about 1/2hour.. I need to go in and straighten/tighten things up a bit but it was getting dark in the carport.
I found it really simple to remove the torx and just press down and pull out the tubes (didn't remove them all the way at all).
I chose to poke hole/put the screws back on the outside on the right because I'll be using those connections for a phoneholder thingie. On the driver's side I replaced the torx before wraping the cover so they are hidden underneath.
Here is a quickie pictorial ... proving to any female out there that we can do mods too.. go for it!
http://home.comcast.net/~eeniemini/
#103
#104
I thought of it after my friend complained about me poking holes in the right side... I justified my action (post-poke) with the fact that I will be adding the phone holder and would need access to the screws.
#106
#107
#108
#109
The two black/red photo's above are my car. I removed the tubes all the way to mount the leather and ensure it was good and tight. I only put the top screw back in at this point. The downtube covers and shift/brake boots match perfectly and look good. Quality products from Redline.
I agree Great product!
#111
I had the same lighting issue. By taking them completely off, I was able to put the leather on inside the house under lots of light. At the top, I used a couple of drops of superglue to hold the leather on the inside of the tube and clamped with some clothes pins. That way, when re-installing everything stayed tight.
67morris
12-01-2015 12:53 PM
Colt45Magnus
09-14-2015 03:12 AM
Marktheman
09-06-2015 06:15 PM
09-02-2015 09:05 AM
