Interior/Exterior 1st chip - need advise from exterior experts
It happened today... just an hour ago....my first rock chip from a stupid and rude Chevy pickup. The rock hit my roof and left an ugly chip is a little under an 1/8 " and down to the metal. Thankfully, there is not a dent also. Will I need to have my roof stripped and repainted or can it be repaired so that it is not visible? Should I have the work performed at the dealership or use a really good body shop?
I can't believe my MINI already has a chip... it not even three weeks old and only 598 miles on it. I need to get my MINI fixed quiclky and correctly.
Thanks for the advise....
very sad... Marlow Main
wait a chip under 1/8"? you mean like less than 2mm? i say just get
touchup paint and apply with a toothpick with the tip tapped flat.
let capillary action do its work. dont use the brush.
i have a bigger scratch from my first drive on my G35C. a dump truck
passing by on the other lane dropped a rock. nice 8-9mm scratch on my
front bumper.
front bumper.
Marlow Main, do not, repeat NOT take this to the dealer! You will end up paying hundreds of dollars to get this fixed. Instead, get yourself a bottle of white touchup paint and a bottle of clearcoat. Apply 2 coats of white to the chip. Top with clearcoat until the surface is higher that the surrounding paint.
Knock down the surface with 800 grit wet/dry sandpaper, and polish to your satisfaction. Add wax to complete the repair.
Cost of materials: ~ $20.00
An afternoon bonding with your MINI? Priceless.
However, if the chip is OVER 1/8", then the best thing to do is trade the car in on a new one. It will never be the same and consider it a lesson learned about getting clear bra for the roof
MM, relax. You are not going to do anything irreparable. The worst that can happen is that you end up with a boogery looking repair, which any competent detailer can make right very quickly.
Go to your local auto parts store and look at the touchup paints. Choose a white that is close to yours. If needed, ask to take a couple of bottles out to your car to compare. It doesn't need to be an exact match, just real close. You probably want a white that is a little brighter than yours, because the clearcoat will tend to yellow it out a little.
Follow the instructions above, and you will be a happy MINI owner.
You can do this!
You can do this!
the dealer will have touchup paint. it comes in a base bottle and a
clear coat bottle. if you're not very fluent with applying paint and
want to do it in once step, you can actually mix the basecoat with
the clear and get a glossy finish.
get a small yogurt cup or something plastic, use the touchup brush
to put a basecoat dab in the cup, then put another dab of the clear in
the cup next to the base coat dab and mix a little portion of the dabs
with your toothpick and apply.
Here's a simply step-by-step
Here's a simple step-by-step guide to repairing chips which has worked well for me:
http://autopia.org/forum/guide-detai...nt-clinic.html
scroll down until you see the section titled " CHIP & SCRATCH REPAIR".
Have confidence and patience. Good luck,
Stephan
Stephan
I did and was very satisfied. The kit comes with everything you need to do the fix right, except the paint, which I got from my Mini dealer (and nothing that you would need to do it wrong). My first thought was to attack it like I would a paint chip on anything else, but NAM advise led me to the langka, and it is much easier, I think.
Interior/Exterior Filler neck/gas cap insert piece, paint peeling for the 8th time now?!
Systemlord
09-19-2015 02:57 PM
