Interior/Exterior MINI Custom Paint job?
Hey, my first post here, just wondering if anyone has had an aftermarket paint job done on their mini? My wife has a 05 mini, silver with black roof, and the paint job is really poor quality. I am not sure if all mini's paint is like ours, but its almost as if the factory forgot to clear coat it. The mini is stored outside but is covered alot of the time, however the paint has large mineral deposits on it and the roof has some paint chipping off. I am pretty sure the cause of it is a combo of poor paint and living next to a resovoir.(water evoporates off and settles when the sunsets, however my F150 is not effected) I am currently dealing with Mini to have a mechanical problem fixed which is much more complicated than it should be, and I have not brought up poor paint with dealer yet. I am just wondering if I wanted to get the mini repainted for my wife can anyone suggest a place or have info on cost, or anything. I live in LA. Any info would be helpful. Thanks in advance.
vI am going to attempt that route, but so far my experience with MiniUSA and my dealer has not been good. Basically our mini has a strange mechanical noise when going from a cold start and shifting into first gear. Our dealer agreeed with the issue, but said they did not know how to fix it or what the cause was. I am still waiting for the regional tech to go over my mini. So for me, the dealer does not know what time it is if you know what I mean, but I will for sure give it a shot! No one has had any mini paint issues but me? bummer.
I am going to attempt that route, but so far my experience with MiniUSA and my dealer has not been good. Basically our mini has a strange mechanical noise when going from a cold start and shifting into first gear. Our dealer agreeed with the issue, but said they did not know how to fix it or what the cause was. I am still waiting for the regional tech to go over my mini. So for me, the dealer does not what time it is if you know what I mean, but I will for sure give it a shot! No one has had any mini paint issues but me? bummer.
brassknuckle... does your MINI come equipped with the Limited Slip Differential (LSD) option? If so, I'd be willing to bet that the mechanical noise is simply the wrong fluid in the differential. It's a known problem that occurs in a LOT of LSD transmissions (which were only available for 01/05 builds and onwards). It doesn't cause any damage, but the noise is annoying. There is a TSB to fix it... I used to have the problem but my dealer replaced the fluid and the sound is gone.
I don't suppose you still have the build sheet that came on the window? They actually give you two... one on the window, the other with your owner's manual.
The build sheet would tell you exactly if you have the LSD.
LSD has never been standard equipment on the MINI, it was always an option, but only for MINIs built 01/05 or later. If your 2005 MINI was built in 12/04 or earlier, then it definitely doesn't have LSD, and the noise is something else.
It must be something else then. Good luck getting it fixed!
If your looking for something custom, feel free to check out my site.
www.lambspeed.com
Any color under the rainbow is waiting for you!
www.lambspeed.com
Wohnson89
06-10-2020 04:53 AM
jrezzo
08-09-2015 10:32 PM
