Interior/Exterior Front Fog Lamp Mounting
Apart from the fact that you will need a hole drilled for each lamp, is there any reason why no-one mounts their front fog lamps in the same way as we did on the classic Minis .... straight onto the front bumper? I own my Mini and cannot work out why I would want to pay someone for a bracket that is NOT REQUIRED???? Anyone got any comments??
Paul
Paul
1. the bumpers are just covers made of a composite material and are pretty flimsy if used to support weight. Where as the Classic bumper were made of metal. I guess you could drill and find the actual metal bumper underneath.
2. Most current driving light housings are not shollow enough to fit the distance from a mounting location on the bumper to the grill on the bonnet.
These are just my opinions. correct me if I am wrong.
Aren't there holes in the front bumper for the fog lights already? Even if you don't have fog lights ( I don't ), there is a hole with little black plastic louvers. Or, are you talking about driving lights.... can't say I recall seeing those in a hole, though
Wait, you mean just screwing them to the bumper, right, not burying the light in a hole. I think the "plastic, not metal" answer sounds like it.
Paul
You'll find that the plastic cover won't support much weight. Under the plastic cover (the painted part that you can see) is a small styrofoam-like impact absorber and then a metal reinforcement bar. The styrofoam-like material is made to crumple for low-speed impacts and the metal is for the harder impacts. You could drill into the metal impact bar for more support but that would require removing the plastic cover to see where to drill, etc. Believe me, the bracket is easier and cleaner.
07-16-2020 12:54 PM
08-19-2015 12:51 PM
Powershift
08-16-2015 05:14 PM
